Elevator->flap trim capability.
Evidently, I'm missing something, both in how to program my 7 CAP radio, and how to post on this site. I've got my aircraft configured with dual aileron sevos, channels 2 & 6, normal configuration for elevator, rudder and throttle. I have a single flap servo plugged into channel 5. Flaps are controlled with 3 position switch, G, to have up, 1/2 and full down positions. The ailerons operate properly with the flaprn selected on, diff set at 0. I have set the ELE->FLP to ON, RT set to -50%. When the flaps are set to 1/2 and/or 100%, I am wanting to have some down elevator applied. No movement when switch G is set to middle/3rd position. Any assistance would be greatly appreciated.
Clint Biediger. |
RE: Elevator->flap trim capability.
When you set the ELE->FLP mixer, you are controlling flaps when you move the elevator. The flaps will not affect the elevator's position. You need to use the FLP->ELE mix to adjust the amount of elevator travel with flap deflection.
