Firmware updates for 14MZ, 12Z, 12FG, 8FG!
Futaba has just released new firmware updates for all four of the above mentioned transmitters. There are a TON of new features in each of these updates. It's almost like getting a new transmitter!
Download the update for your transmitter at: http://www.futabarc.com/downloads.html Steve |
RE: Firmware updates for 14MZ, 12Z, 12FG, 8FG!
looks like we no longer have the option of not transmitting on 2.4. least i couldn't access the "on air" icon to try and change it.
Hi mongo,
You just need to have the 72 or 50 Mhz module installed when you power up, you can then go into the Frequency screen and select which channel you want. Sincerely, Krysta Product Development & Support Specialist Futaba Service Center USA [email protected] |
I liked the option to disable transmitting - even on 2.4 - since it saved on battery power when I am programming the 12FG.
No biggie... Downloaded it... installed w/ no problems... I love the bigger timers! That alone was worth the update. You and Bax keep up the great work! r/s... Roger |
Does this firnmware update wipe out all my existing models and setups?
Thanks. Jeff |
An easy update for my 12FG (oh, what a radio once you pass the aha! moment of programming)
I haven't explored all the new features but the large timers correct a bit the low volume beeper problem and the possibility of changing models from the main screen is great. I guess that the new firmware means that the 12FG is here to stay for a while and we will not suffer constant new model releases like other brands. |
ORIGINAL: nxtdoor Does this firnmware update wipe out all my existing models and setups? Thanks. Jeff |
ORIGINAL: mongo looks like we no longer have the option of not transmitting on 2.4. least i couldn't access the ''on air'' icon to try and change it. Once you're ready to actually transmit, make sure the throttle is closed, and select the RF OFF icon as you used to do. r/s... Roger |
I'm still using the as shipped software in my 12FG, v1.3 I think. Do I need to step through the previous updates or can I jump straight to applying v2.0 ?
You can use the latest update. It includes all prior revisions.
Please realize that this is a support forum. If you want to have a discussion, please take it to the regular radios forum. If you have questions you want to ask of the Futaba Support staff, please start a new thread. Thank you. |
