DA-100CC canister ??
1 Post
Hi , i m new to this giant scale planes , as recently i bought a Sebart Sukoi s29 2.6M 100CC plane , and i have a used DA100 from my friend .
Question is i want to put in the canister .... but were told by some local flyer that it would cut down power out put ..?
Is that true ...? Advice please , any recomamdation or advice are welcome..... Thanks.
1 Post
RE: DA-100CC canister ??
ORIGINAL: novayusa
Normally canister should good to power output of engines than dump muffler unless the canister is a wrong design product.
CA
KS-86 rear dump canns with a total header length, measured to the baffle inside the cann of 15.5 to 17" will give equal to stock power. Very quiet too.
These work pretty cool too!
You can choose MTW or KS canister if you don't feel those are expensive otherwise you can choose Chinese products like MT C65 with MT H102 header or some else. The link below for your reference.
http://mtenginesusa.com/products.asp...ne+Accessories
1 Post
ORIGINAL: novayusa
Do you use this MTC65canister ..? will it deliver more power ? I have check the ks and mtw .. hemm abit expensive to me ...!
To install the single MT C65 and MT H103 on 50cc gas engine. Itdelivered more power tome. I think it should be worked on 100cc Twin with a pair of MT C65 and MT H102 also.
