Zenoah G62
My Feedback: (98)
Zenoah G62
Guys I have a G62 that I need some info on. The manifold between carb and engine(Plastic or phenolic) Is very long. Maybe 1.5 to 2 inches. Can I shorten this without hurting the running of the engine? I am aware of the pulse hole and might have to modify this.
RE: Zenoah G62
If it is the original one that does not turn the carb for easy linkage hook up, You can cut it down to ½” and it still work.
B and B sells one that is shorter but all it is one cut in half.
Milton
Milton
RE: Zenoah G62
Here is one Horizon sells that is shorter and makes it easer to hook up the crab linkage
http://www.horizonhobby.com/Products...rodID=ZEN16210
Milton
Milton
RE: Zenoah G62
I make mine using three layers of 1/8 inch G10. the center layer has the pulse hole track from the carb hole to the engine hole. the outside layers have the bolt pattern respectively as required for the engine and carb. Epoxy the three layers together.
Regards, Richard
Regards, Richard
RE: Zenoah G62
Quick G-62 question: I have an airplane that has a big enough cowl to use the big muffler that came with the engine. I have been using a slimline pitts muffler from the onset. What might I see with the original muffler? More power, quieter, etc.
Thanks in advance.
Thanks in advance.
RE: Zenoah G62
If you are talking about the twin exit, slanted muffler, I would say around the same rpm perhaps slightly less. The stock muffler is not that loud (ran it for less than a gal. on mine til it blew a hole through it near one of the exhaust bolts) and replaced it with a B&B side dump. Much louder but a lot more rpm too! The stock muffler's two tubes travel way up inside near the top of the muffler making it restrictive.
RE: Zenoah G62
Lifer in my tests I found the Zenoah muffler very quiet. Problem is it will cost you 500 to 600 rpm and it is heavy. Better off with something like a J Tec wrap around or side dump or one of Milton's side mufflers. Very light and no loss of rpm. He has them for sale in the ads section or on his website for a very good price. I believe they are about 40 bucks shipped.
RE: Zenoah G62
ORIGINAL: drbenz
I had to go to the clinic to get rid of my crabs!
I go to the theater and get me a big bag of pop corn., Every time I take a bite I put one in my pants, When the crabs go for a drink of water I change seats
Milton
RE: Zenoah G62
I like the Zenoah G62 engine, have mounted it on several bikes at work. You should check its specifications, that might help.
Specifications
- It is a 2- Stroke type of an engine.
-Its bore measures 47.5 mm.
- It uses a single cylinder.
- Uses Ring Cylinder type.
- Has a Benchmark prop of 22 X 10 APC at 7800 rpm.
- Uses a Ball Bearing Crank type.
- Crank shaft threads: M10 X 1.25.
- The specific engine weighs 73 oz.
- It has a consumption capacity of 3.8 cu. In. (62.0 cc)
- RPM range is 2000 – 8500.
- Stroke is 1.40 inch (35.0 mm)
Source:http://www.motorizedbicyclesportal.com
Hope that helps
Specifications
Hope that helps
