SPE 26 Engine and plane balance
Hello,
i am new to unleaded gas engines. The SPEwas given to me by a friend that has not used it for a while and now i get no spark when i turn the engine, I replaced the spark plug and nothing but noticed the ignition module gets really hot is this normal? can this be causing the problem? Also should Ibalance the plane with a full tank or empty tank?
MB, CANADA
RE: SPE 26 Engine and plane balance
You should always balance the airplane with an empty tank. (keeps from having a too aft CG when you are low on fuel. )
