red lion 58
RE: red lion 58
Lighter than what?
More powerful than what?
What is it's torque curve like?
What are the REAL power figures like (not made up numbers for the advert - actual figures, especially in the RPM range where you fly).
From the information I have been given, they are not a bad engine. Typically chinese Manufacture (being made frmo a lot of off the shelf parts - which helps down the track should you wish to repair it). Mostly good out of the box.
Are they the most powerful in the 55 - 60cc class? - Nope
Are they the lightest in the class? - Nope
Are the power and weight numbers for it acceptable? - Most likely depending on what you wish to use it in and how you wish to fly it.
Buy one, try it and report back. there is very little actual true experience posted on the threads about it so far - someone needs to impart that info for the next person that asks
RE: red lion 58
ORIGINAL: Tired Old Man
Geez, you're starting to sound like me
I guess I have learnt well master
Isn't it funny how the world goes around.
Some time ago, I saw a post from a person that I look up to on engine knowledge. He was thanking another very experienced engine man for getting him involved in these engines all those years ago.
You are one of the people that I look up to in engine knowledge. (hey - don't get to big headed - you ain't the only one).
RE: red lion 58
ORIGINAL: kerwin50
I've been looking at the red lions 58
It's supose to be lighter an have more power
I've received two RL58 to repair , both with serious damage caused by the small bearing used on crankshaft.
When the rear crakshft bearing fails, and take too much play, the big end needle bearing breaks, and broken parts of needles causes serious damage to the engine.
I think manufacturer must change this small bearing.
The engine is much lighter than DLE55 because all main parts are ligther. Crankshaft, rear bearing, crankcase .....
Regards
My Feedback: (303)
RE: red lion 58
Displacement : 58CC
Bore : 47.5mm
Stroke : 33mm
RPM Range : 1300-8500rpm/min
Output : 5.6hp/7500rpm/min
Weight (engine+muffler+ignition) : 1470g (3.24lbs)
Warranty : Two years
Bore : 47.5mm
Stroke : 33mm
RE: red lion 58
ORIGINAL: kerwin50
Two out of how many?
Some years ago Bryson had a few front bearing failures. But alot of it was due to poor breakin.
I don't know how many RL58 have been sold in my country because there are no oficial dealer. But i think a few units.
Maybe both engines have failures by a poor break-in, but i'm sure small bearings on a big bore engine is not a good idea.
Regards
RE: red lion 58
Brison lost the majprity of their bearing failures due to impact damage. The evidence was clear when they were returned for "warranty repairs". Almost all the cranks had sustained some form of damage that could be seen during the tear downs. Unfortunately the engine owners elected to lie about what had happened with the engines. I had on of those that failed a bearing but it had experienced a few prop strikes when mounted on a GP 1/3 Pitts.
RE: red lion 58
Off topic here a bit, but will prop strikes sometimes/maybe/always cause bearing failure? I've had a couple broken wooden props on my DLE55 from rough landings/flexy gear causing the tips to hit while still running, and yesterday did a bone head move in the pits where the prop hit while running and the nose went down, resulting in a 22" prop becoming a 12" prop [&o]
RE: red lion 58
I can't speak for all other engine makes but you should have nothing to worry about with the DLE, there has been no history of prop strikes leading to con-rod bearing failures that I've seen. Impacts with Terra firma though have caused many main bearing failures, you can feel the effects in your hand while turning the engine over with the plug out.
RE: red lion 58
Thanks, Jody. You saw first hand a real impact my DLE55 had last year, and replaced the bearings for me, as well as a few other necessary parts. I've got 3+ gallons thru it since then, and all is fine, but have had the above-mentioned "prop strikes". Thanks for the info.
RE: red lion 58
ORIGINAL: mpascual
Regards
ORIGINAL: kerwin50
Regards
I had talked to the manufacture about this engine and was sent information about how much stronger and better it was than the other popular China made engine and that it had been tested for over two years in China.
Looks like I was being feed a lot of propaganda. LOL
Translation for propaganda == Bull Crap
Milton
RE: red lion 58
Needle bearing failures has been the most common problem in China made engines, Some have tried to correct it other do not care.
If they have only been a few of them sold and are already having them to fail, what does the future hold for them.
They just will not spend a extra $4.00 for good needle bearings. ???
Try one out and see if they hold up for you.
