gassers and metal gear servos
<hr />Av8tor, I have quite a few JR servos. They all rotate the same as Futaba....except the 506 I have. The 505 and the others rotates like most all other servos. I went to the Hitec web-site and they have about 4 -6 that you can oder...it says reverse on them. Too match power and speed...the "Y" with a reverser with a trim screw seems OK. I hope. Also I hope EMS is a good brand. Capt,n
Choose whatever you are comfortable with! However safety is paramount, where injury and human life are concerned!
Just finally managed to read through the entire thread, so done with great interest. Relatively new to gas engines so all too happy to soak up the cumulative experience available. Based on my current skill level and personal interest in the hobby, I don't see myself venturing into 3D flying right now and as such have turned focus to IMAC type flying. I am therefore particularly keen to get a feel for what servo(s) would recommended for 50cc size model that will be sufficient for the type of flying I will be doing. I have seen what I consider general recommendations, however, would anyone be willing to say whether or not I should go for digital metal gear or would analogue metal gear be sufficient.
Dale
zx32tt
Alan
I was wondering if you may be flying at the speeds or RPM,s where the engine shows it worst viabration level? It seems like various engines have a "bad RPM levels & that RPM should be avoided. Then there is the prevention of control surface flutter that has to be aware of. Lots to learn in this good ole Hobby! Capt,n
seeing in another thread that ignition interference can be an issue, is there any set distance from engine that the servos need to be?
these are going into a ww1 craft so up front and close to the firewall is going to be mandatory.
I don't want to clog up summerwinds' thread with our missives but keep three things in mind about RFI;
1. Conduction
2. Radiation
3. Just because you have survived an installation, it does not mean it's right. All you need is the planets to be aligned right and you'll go right in.
Thanks for all the emails. Dan.
Simply set everything up right, use good equipment, and perform the requisite range checks like you're supposed to.
Ed Waldrop are you still listening,
1. Conduction
2. Radiation
RE: OPTOKILLSWITCH
The fact is that we use Opto isolators for the front end radio signal that isolates all of the radio signal .<o></o>
A guy could understand it like this the radio section is turned into a Light beam and is transmitted to the Ignition side once received the light <o></o>
Is converted back into a pulse stream for the Ignition side of the unit that have a Filter cap and a very fast small signal diode to Block any noise and sent to a Mos-FET to turn the Ignition on and off .<o></o>
The fact is even if the ignition was flooding noise and anything else it has no way to “JUMP” into the radio side since it is Light that is transmit source of the on/off action .<o></o>
The noise would have to turn into light get inside a sealed device and then start transmitting the noise !<o></o>
Impossible it’s just like Smart FLY they use a 2 Pc system we use 1 unit a TX and a RX all on 1 Pcb it is in fact the exact same way smart fly does his unit.<o></o>
<o></o>It’s like this he has a TX unit then it has the light TX’d to the RX side of his unit .<o></o>
Think of ours like the TOP being the TX and the bottom is the RX same way he does his only ours is a single TX /RX system.<o></o>
<o></o>The White module on the Top is the Opto isolator we use it is where the Light goes from Tx to RX .<o></o>
<o></o>Thanks for emailing me and keep me posted .<o></o>
<o></o>We have less than 50 returns on over 65000 units sold and have no issues with them in any way .<o></o>
There are a lot of hatters out there that hate to see anybody but them survive <o></o>
<o></o>Ken Anderson
So there it is. I have not violated any rule, instruction, or self-defined theory. I use ferrite coil and block noise filters and twisted servo extensions to prevent noise in other areas: ie..throttle and choke servos, and any extension over 18". It works, I have not had one problem with noise in any of my planes before or during a flight, it is my choice. Attention to detail and setup procedures pluspre-flight testing at all throttle ranges is imperitive before a plane takes flight.I personally have not seen any failures of this product but you can be assured I will continue to use them until proven otherwise. I am planning on using their Blue Board power system in my next plane along with the kill switch. Like I stated, I am very safety concious and do everything in my control to be safe. I like the feeling of being able to shut down my engine on a moments notice and not haveing to wait for it to run out of gas. My choice. End of discussion.
And Pat thanks, we agree at least on a couple things.
Ed Waldrop
Sorry guys I didn't mean to write a book!
Captain,
My DLE had 5 flights on it. So my speed fluctuates. I did notice that at idle it shakes quite a bit.
Alan
How about the airplane you have the DLE on....is it a plane designed for what you are doing with it? That may not be the correct wording!!!! Not meant to offend you...just wondering. Best Regards capt,n
Ed, I sent you a PM. Dan.
Everyone have a nice one, I am outta here!
