What do you think?
My Feedback: (13)
OR
RE: What do you think?
it's the starter part of a weedeater with a little piece of aluminum turned to fit the OD of the starter pawl thing and the OD to match the ID of the piece of PVC I had on hand, carved the PVC to the shark tooth shape about 1/4" deeper than the largest prop I planned to use it on (my biggest prop is a 22x8 I believe)
I got a very large photo....easy to make smaller....hold the crt key down and spin the thumb-wheel on your mouse to make it the right size. Nice home built starter. Good job. Capt,n
So very coincidental that this thread was brought back to life just now, as just this weekend my buddy Dale and myself started up my mag. gnition Zen G45 that had been laying idle since 1998. All I did was remove the spark plug to drain the oil I had put in the engine to guard against corrosion, opened up the carb to check the mesh filter and the diaphrams, spray the innards with carb cleaner, give it a good blow out incl. the needle seats with comp. air and buttoned it all back together. Connected it to a gas tank with 32:1 fuel, and with both needles opened at 2 turns, choked the engine to fill the carb with fuel, and after a few spins on it's Terroid spring the engine roared into life. Just can't beat the overall reliability of a mag ignition.
Karol
Karol
#31
My Feedback: (14)
I still have one NIB G23 late edition and one NIB Ralph Cunningham G26 Lite that I have been holding on to, waiting for my cataract operation to be done and over with. They, or I should say, their siblings, were wonderful engines. I still have a new, unrun, Brillelli 36cc engine also. Talk about rare these days.
Ed Cregger
Ed Cregger
#32
Ed,
I am still kicking myself as I recently let one the latest models G23 slip through my fingers. It was almost NIB and mine for the taking, but procrastination on my part caused me to lose it.
Karol
Karol
#33
My Feedback: (13)
OR
ORIGINAL: captinjohn
I got a very large photo....easy to make smaller....hold the crt key down and spin the thumb-wheel on your mouse to make it the right size. Nice home built starter. Good job. Capt,n[img][/img]
#34
ORIGINAL: ggraham500
Please explain what a ''CD unit'' is. Is this a magneto system?
