Zenoah G45
My Feedback: (38)
Zenoah G45
I have few different planes with Zenoah G62 and GT80 with spring starter to fire them up. I like the spring set up which make starting a breeze.
I am finishing a plane which will have a Zenoah G45 without a spring start.
My question is this......
I never started a Zenoah without a spring starter, is it difficult to start a G45 without the spring starter?
All the help as usual is appreciated....
Fabio
Fabio
RE: Zenoah G45
Most all mag ignition Zenoahs can be hand started quite easily though some folks have difficulty doing so. The trick or rather the way to have them hand start fairly easily is in the positioning of the prop. Follow the instructions regarding this carefully and you will find them quite responsive to hand starting.
Karol
Karol
My Feedback: (20)
GA
RE: Zenoah G45
Here is a video of how I would start my Zenoah G45.If the engine is new,it will be a real bear to start.mine was new and it was hard to start then,but after getting it started,I let it run for 30 minutes at around 2000 rpms,after that it started a lot easier using this method.
I also found that the zenoah likes a lot of fuel when trying to start it.Hope this helps.
I now fly a 2.3m Comp Arf with a DL50.much easier to start with electronic ignition.
Roy
http://www.youtube.com/watch?v=8ij-qzDVdpc
Roy
My Feedback: (19)
RE: Zenoah G45
ORIGINAL: karolh
To each his own.
Karol
To each his own.
Karol
RE: Zenoah G45
ORIGINAL: jerdavis
They start just easily or not as a G62......You need a spring starter (or electric starter or electronic ignition) if you want to fly on a predictable basis.
JD
JD
My Feedback: (35)
CA
RE: Zenoah G45
Does anyone out there know if you can flip the manifold and carb (as one unit) upside down to allow the needles to be on the bottom and the throttle and choke to be on the top?
Any experience with this would be greatly appreciated. It would sure make the throttle hook up easier on the plane I am putting together.
Thanks.
Thanks.
