pop-off pressure walbro dle55 ?
My Feedback: (16)
RE: pop-off pressure walbro dle55 ?
http://www.lawnmowerpros.com/detail.asp?id=400-606
WALBRO 400-606 Kit - metering lever spring $41.95
Is a plastic 18 compartment box with an assortment of metering valve springs
It measures the lever height. The center leg should touch the lever, but without opening the needle valve. If you sweep it over the lever, the test pressure should not, or ever so slightly drop.
Beware. Each carb type has it's own measurement, and can be with, or without, the gasket. Read the F**g manual if in doubt, or if all else fails.
ORIGINAL: boolat
Hello,
Could you give information concerning this:
it measures what? and why? something that has to do with the pop-off pressure?
thx
Hello,
thx
#31
ORIGINAL: boolat
works fine in general,
slowed not very stable
to have a slow I must remain stable in 1850rpm.
