G-38 w/ CM6 spark plug
AL
No No, I didn't see a new offering from Zenoah that has a G38 w/ a CM 6 plug.
I am going to put a CM 6 plug in my G38 to get it inside the cowl of a plane I am working on.
A friend of mine mentioned to me that the G62 doesn't like the CM 6 plug, is he correct?
If he is correct are there any other of the Zenoah engines that don't like the CM 6 plug?
DC
RE: G-38 w/ CM6 spark plug
If it makes spark the size is inconsequential....All you need is the correct cap and an adapter from 14 to 10mm....Bear in mind the CM6 is not a resistor plug and might cause a problem with RF....The only resistor caps for 10mm spark plugs come with RC EXL, DA, 3W, and most other ignitions....If you use one of these caps the coil wire is larger diameter...
