start dle55 problems
Hello.
I start the engine without problems DLE55.
The only problem I have is when, after landing I have trouble restarting the engine directly with choke on?
That is to say that I am forced to close the choke start propeller 3X once heard the crack I open the choke and revive the propeller to start ...
I have to do every time this method to start!
Thank you for helping me
RE: start dle55 problems
ORIGINAL: w8ye
This is normal unless there is a hot shut down and immediate restart within a few seconds
ahhh this is normal [X(]
I thought we could start directly with choke open once the engine is cold.
thank you w8ye
ORIGINAL: w8ye
It will start easier if the low speed needle is a little richer but then the engine does not run as well in the air
I would rather mine be like yours is now
Thank you again!
