If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 42
  1. #1
    Join Date
    Jan 2004
    GAHANNA, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DLE 30 stalling
    I have a dle 30 with about 1 1/2 gallons thru it. It starts and runs great, but here is the problem. It is prone to stalling when inverted or vertical. I am turning an 18 x8 at about 7800, just a bit below peak. I have checked and re-checked the fuel system and all is fine. It is the latest version with a rear carb. I would appreciate any suggestions. Thanks.
  2. #2
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Did you change the spark plug to the NGK CM-6 yet?
    The DLE spark plug is very unreliable
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  3. #3
    Join Date
    Jul 2010
    Snohomish, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    I have about a half gallon through mine so far, seems like it does not like to run at low idle for very long, seems to choke out and is hard to start there after. Does yours have this symptom? Mine seems to prime easily with about 5 flips.
  4. #4
    vertical grimmace's Avatar
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: Cliff.Baker71
    Sounds lean, on low end
    Let's just say, they will be satisfied with less. " Ming the Merciless
    BUSA Bro # 13
  5. #5
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Or rich. Sometimes a rich engine will idle, then slow down, then quit as the engine slowly loads up with too much fuel. Hard starting afterwards might be because it is flooded.
    AV8TOR
    If it is not SCARY, it is NO WHERE NEAR powerful enough!!
    All R/C planes have expiration dates---> It's just not printed on them anywhere!
    Just because it's not a good idea doesn't mean it won't be fun!
    Never underestimate my level of immaturity.
  6. #6
    apalsson's Avatar
    Join Date
    Jun 2003
    Coffs Harbour NSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    The mid range will tell you if the low end is richh or lean (assuming the top end is correct)
    Burbly mid range indicates a rich low end
  7. #7
    Join Date
    Jan 2002
    Hesperia Michigan, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    If it chokes out like you say... the low end mixture is too rich! You can tell that too on restart...it will be hard to start and puff out smoke just before it starts again. Capt,n
    I never met a engine I did not like !
    6/8/2015 http://www.lambertsrc.com/
    http://pure-gas.org/about
  8. #8
    jerdavis's Avatar
    Join Date
    Sep 2004
    Pine Grove, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Cliff Baker:
    My DLE 30 acts the same.
    It wouldn't idle very long....sounded like it was loading up rich, but it would idle worse whether adjusted richer or leaner.
    In a high G turn at idle it would act like it was running out of fuel and die. By adjusting metering pin lever, closer to the diaphragm, (so the diaphragm can open the meter pin easier) the symptoms have improved. (I need to fiddle with it more.) It looks to me like there isn't enough vacuum at idle to open the metering diaphragm and pin unless the lever is adjusted exactly right. Maybe the metering spring is too strong.
    I had turned the carb over from its original position. Thus the G forces would tend to pull the diaphragm toward the closed position, so at idle the engine would die from fuel starvation when making the turns to a landing.
    If the carb was turned the other way it would probably cause trouble when flying inverted.
    Any way, try adjusting the metering pin lever to see if that will help.
    Jerry
    P-47 Thunderbolt Brotherhood #6
  9. #9
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: walleyevision
    I'm assuming this is at or near wide open throttle (WOT)? I had one making me absolutely crazy for a while last season. Same thing, went through everything, incuding carb, several times. All over the carb adjustments. Dead stick landing followed any extended attempt at vertical climb. Then one of the fellow club flyers suggested I hold the nose of the plane up with engine at WOT, just like I did when checking a nitro plane. Well, that point out, with no doubt, the plane was going lean, though I thought I had the carb set up fairly well. Went a tad richer on the high speed and no more trouble.
    Point is, I found though it's obviously much more difficult handleing a DLE30 powered plane, nose up at WOT check is just as necessary to assure proper performance as it was when checking a nitro plane.... FWIW
  10. #10
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Lots of good suggestions, just make sure you're looking for horses when you hear hoves before looking for zebras.
    Is the plug an NGK or original? If its not a CM6 replace it with one.
    Is the plug gap set correctly?
    Does it have a fuel filter inline? If yes, clean it out.
    Have you checked the screen in the carb? Lawn mower shops sell rebuild kits with that screen in them or clean it with brake kleen.
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  11. #11
    Join Date
    Jul 2010
    Snohomish, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Still the stock plug, will replace that right away, yes on the inline filter, have not yet checked for debris. Will reply with results. Thanks!
  12. #12
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Yes, please let us know how it turns out.
    AV8TOR
  13. #13
    Eganwp's Avatar
    Join Date
    Jan 2008
    Calgary, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Rear carb or side carb? The side carbs are known to have the issue, hence the revision change & rear mounting kit.
    If it's rear carb, you likely have a diaphram pressure issue. Tap the cover and run a line into your fuse (pill bottle optional).
    35% H9 Extra 300 - DLE-111 | 33% Lanier Yak 54 - DL-100 | 30% Peak Edge 540T - DLE-55 | SkyWalker Long Range FPV
  14. #14
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: Eganwp
    I agree....most likely cause I think ! Capt,n
  15. #15
    Join Date
    Sep 2003
    NtheStiks, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Don't mean to hijack the thread but my problem is similar with the 30: engine runs fine in the air (some burble at mid-throttle), but when I roll inverted from straight and level flight, dead stick! Think this might also be a needle setting as noted above? Thanks.
    Combustion Addict
  16. #16
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Could be...goes from rich...to too rich...quits..............Not good ! Forgot....look at the sparkplug color....should be lite tan in color. Do that right after a hard run and quick land............
  17. #17
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: F-16WpnsTech
    Stiff fuel line in tank - holding the clunk/pick-up out of the fuel? Does it quit right away or after a few seconds?
  18. #18
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    My suggestion to you guys that have this inverted problem is to fix up a nice padded stand to run you plane and engine inverted. You will need help doing so...but worth the trouble. Capt,n
  19. #19
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    More....when I had my DLE30 cc engineon a test stand I moved the tank 10 inches higher and 10 inches lower than than carb while running....absolutely no change in running. Your milage may vary! Capt,n
  20. #20
    Join Date
    Sep 2005
    santa ana, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    No matter what I do or how I tune my DLE 30 (V1), it runs poorly and invariably dies, either taxiing or in flight (3D flight especially). The engine has a mortal design flaw and I basically got fed up with it. I believe this line of engines was brought to market too soon and lots of unsuspecting customers are paying the price with crashed airplanes. DLE acted irresponsibly and needless to say, that was the last time I bought from them.
  21. #21
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: doublesixes
    Yes. They're junk. If you'll shoot me a PM I'll give you an address you can send it to for recycling. I hear they'll even pay the shipping.
    On a more serious note, if you can't get yours into tune, I have to believe it's broke, or you're doing something wrong. The engine is awesome.
  22. #22
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: ahicks
    If you get a DLE30 with the rear intake...a good carb...and the right CD unit with the correct advance curve, it is kinda awsome. Oh yes & a Piston ring that is not too hard !
  23. #23
    Join Date
    Oct 2006
    winston, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    Change your diaphram spring, several RCGF's had this same problem and id cured them,The spring tension is weak from what I'm told
  24. #24
    Join Date
    Sep 2003
    NtheStiks, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: ahicks
    Right away. After starting, I picked it up, had a friend go to WOT and I rolled it over myself....quit!
    Combustion Addict
  25. #25
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 30 stalling
    ORIGINAL: ahicks
    What I was wondering is if it's quitting after burning the fuel in the line between the carb and clunk, like after the clunk has been lifted out of the fuel because of a stiff fuel line? That might take a couple of seconds (vs. immediately after rolling inverted). That's where I would go first anyway. All else being equal, I'm not sure what else may change going inverted?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
