DA / DL observation
#80
My Feedback: (15)
NJ
RE: DA / DL observation
Can anyone else BUT Tired Old Man answer my question? He can't seem to stop getting personal with his opinions and not answering my questions at all ***!!?? . If not, I'm off this Forum.
#81
It's an exception for a new engine not to make a mess. It is very common that during the breaking in there will be black oil expelled. Chinese engines are no exception. Not better, not worse.
This item has been covered umpteen times here.
#82
I have no problem with a little oil on my plane after a day of flying. With experience you can even read the oil on the plane and see whats going on inside an engine, whether it's breaking-in, doing fine, or is possibly developing a problem. If one has a problem with the oil residue from a gasser burning 32:1 fuel mix I would invite them to run a 3.0 cu. in. glow engine on their plane for a while and see which one they like better. Or they could always go electric.
#83
The amount of oil is relative to the mix ratio used. At 32-1, and I'm presuming at minimum you were using a 50cc engine since that's the smallest DA makes, you were over oiling the engine. You were also likely using an oil that is well noted for generating an amount of discolored residue well in excess of the norm. A 32-1 mix is not necessary for breaking in a 50cc engine when some relatively easy to use guidelines are followed. Thousands of engines are broken in and run (with extreme levels of success) using 40 and 50-1 mixes.
Properly done, the engine would generate either the same amount, or only slightly more, residue than it would during post break in running. The fact remains that all two stroke engines generate waste oil byproducts that exit the engine during running. Where that oil goes, and the amount, is the only question. The mix ratio and type of oil used determines how much oil will be purged during combustion cycles. At 18% to 20% oil, glow fuel still holds the top of the list for slimey, nasty, oil residue.
#84
ORIGINAL: jedijody
#87
Hint: I am not, nor will I be, politically correct. I don't care if someone's feelings get hurt. When that happens it's a personal problem, theirs. I just try to get the message out quickly and accurately. I don't have time to hold hands and get warm and fuzzy.
#88
My Feedback: (15)
NJ
Is 50:1 full synthetic OK for DLE111? (I'm planning on switching from Amsoil/Sabre to Stihl Ultra) What ratios are you guys running after breakin?
Also: is the carb(DLE111 again) a Tillotson brand or copy??
#89
My Feedback: (35)
KY
Now if I'm wrong TOM will tell me. All oils work, some better then others. Full synthrtic is always for me. The big thing is always mix by the ratio of the brand you use. Never add any extra for the wife and kids. If you ask which one is better this thread will go another twenty pages. I use the same for both new and used engines. I don't use a break in oil. What I got is what I use for everything.
You'll notice I woun't say what I us. Thats because someone woun't like it. Dennis
#92
DC
ALL engines are made from the same basic materials, if the manufacturer wants some CYA he will recommend more oil...
FWIW we know from many tests that MORE oil makes MORE power....Like it or not, it' true....[>:]
#93
ORIGINAL: MIXMASTER
My question was about ratio AFTER break in for the DLE111, NOT any other engines.
#94
ORIGINAL: MIXMASTER
#95
I'll diverge from Jody's position and say 50-1 is fine for the 111 after break in. 32-1 will provide a better ring seal during the first 25 hours or so of run time but after seating there's no reason to use that much unless we're protecting the engine from actions of the owner. I have at my fingertips far too many engines using 50-1 Stihl to say that more oil is neccessary.
If the user doesn't know what they are doing for cooling and tuning then more oil is better but it will not save the engine from user extremes. Neither oil ratio nor advanced engineering can offset user stupidity.
#96
ORIGINAL: MIXMASTER
Do the DLE's put out a lot of oil on the plane, when I break in a DA @ 32:1, its a mess?
#98
Plug position is reversed and fuel cannot puddle at the spark plug well. The plug is running warmer and cleaner. Basic cause: gravity. Can't have it that way all the time and still fly aerobatics. A fixed plug orientation only works good for entry level trainers that never get rolled inverted.
