NGH 17cc gasoline engine
No. NGK does make a compatible plug, the ME-8, but it is last on JediJody's list.
I don't know why the NGK ME-8 plug doesn't last but it just doesn't.
the carb is in the front, WHERE IT BELONGS
the carb bolts to the crankcase like it should (no adapter plate)
the cylinder is steel (not chrome-plated)
it has beam mounts, not standoffs
it has a proper rc-style muffler
the only thing that gives me pause is that I'd like to see a little more meat on the crankcase where the carb bolts thread into...just eyeballing the pics, the carb bolt thread area looks a tad thin IMHO.
BUT...overall they seem to have gotten everything right. OS doesn't seem to be listening...
http://www.youtube.com/watch?v=bAsiSVEEwSM
And some rpm numbers after first hour of bench break-in.
Repsol 95 IO fuel, mixed with Motul 800 2T oil @ 5% (20:1) for the first liter, 4% (25:1) the second one, and then oil can be lowered to 3,3% (30:1) ratio.
Then, some needles tuning , and :
13x8 Master Airscrew K series : 10.900 rpm
14x6 Master Airscrew K series : 10.650 rpm
14x7 APC C2 10.200 rpm
15x8 APC C2 8.700 rpm
15x8 XOAR C07 madera 8.400 rpm.
After the test, the con-rod bushing looks like new.
I know those numbers are nosense for some people on this kind of bench test, and the video des not show anything new. Engines needs to perform on the air mounted on airplanes, but many people wants to know rpm numbers to compare with their current glow engines.
Regards
Thank you for testing those props on the GT17. It is helpful information!
I especially appreciate your taking a look at the connecting rod bushing.
You have more fuel through yours than I do but I am running a 14x6 Master Airscrew K series on mine right now and I'm approaching your RPM on short bursts (I believe I can tune for higher RPM than I am but I don't want to run wide open too long at this point).
Any other comments on how your engine is running?
Paul
Paul
There is only one place to buy the rimfire spark plugs and that's from them direct, they control the price and the price is what it is.
http://www.jerry-howell.com/RF-Plugs.html
http://www.modelflight.com/larrydavidson.html
http://www.cncengines.com/orderpage.html
http://www.morrisonandmarvin.com/links.htm
http://woodysengines.ecwid.com/product?310464
http://www.model-engine-plans.com/pa...sparkplugs.htm
Did Michael Chow redesign the muffler? I need another small gasser for my new project the NGH 17 might just do.
Probably some CYA involved there..He made and tested some protptypes, settled on the original Rimfire...
Some of the Rimfires last 500 hours in a converted OS 70, the ME8s lasted 100 hours or less...
The Chinese 1/4 32s are way better than the NGKs.....And cheaper...
.......................someone asked if the NGH 17 addressed the ''muffler issue.'' I did not see any feed back regarding that point. [&o]
Might mean they put sleeves in?
Two halves have one little O'ring seal mounted around the baffle to avoid leakage, but in my first engine does not seal well.
The factory is working hard to supply a very reliable and trouble free engine, and soon will be available a new design pitts style muffler for this engine (welded) .
Regards
It looks like this little engine is already rivalling a O.S. 91FX!
my 91FX is turning a JXF 14x8 plastic prop at 9800rpm.
Fit a bigger 15x8 and it bogs down in the low 8000's. Needs a pipe to bring it back on song with that prop. The NGH 17 looks to be the ticket.
Any chance they can place it on a diet before the final production version is released?
I don't think so .....
This IS the production version.
Regards
The setting from tweaking the HS needle on the resulted in running lean in the air at higher airspeeds. The engine would rev from idle to WOT nicely but as the plane accelerated it started missing. On the assumption that it might have something to do with the prop unloading a little and running higher RPM's than on the ground, I brought it back down, richened the HS a very small amount, test again, and repeat. Since it seemed to improve with each little adjustment, I kept adjusting a little richer until ran well WOT.
I've got some lower RPM four cycling going (starts when pulling back the throttle through about 33-40% throttle) on right now and I'm leaning the LS a little at a time (while keeping an eye on the high end since they interact).
It likes being started with the electric starter. I understand that hand starting improves as the engine breaks in.
I may try the carb diaphram mod just for yucks when I get a chance.
Paul
I do not currently have a 4.8 volt battery in my parts locker. Is there an issue in using a 6 volt battery for bench testing only?
I made the leap of faith and purchased a NGH from Agape Hobbies. I live on the West Coast - the engine arrived within 3 days of purchase. Talk about great service!!
I have that one and i just plugged it into the Gear channel and the ignition is powered off the spektrum radio/A123. I put a car switch in line so I can kill motor w/o killing aircraft just like having a separate battery.
If you are running 72Mhz, do not use a common battery. 2.4 ok... interference.
I ran a 15x4 wide on mine and it rips too easily. I kept it from ever leaning out top end, but it easily overrevs it, so I purchased a 15x8 today... will continue break in.
Also if it idles high, richen low end and try again.
I've got a 15x8 and a 14x9 3-blade that I'm going to try. I'd guess that the thrust band on this thing is below 9,000 RPM let alone 10,000. I'm going to shoot for something in the 8,000-8,500 WOT on the ground range once the engine is broken in a little further.
Paul
Compaired to the JBA 15, I am very impressed with the initial preformance of NGH 17. The stock muffler has different manifold demensions than the JBA 15 and it still leaks exhaust residue. An application of High temp copper sealent might correct this issue.
Anybody done a comparasion between the DLE-20 and this engine??
Cheers
The DLE-20 puts out a lot more power, but is physically larger - particularly with the rear carb.
The NGH GT17, with its front carb, dropped right into the existing motor mount spacing from a Saito 100. It will work in situations that would require extensive rework to fit a DLE-20.
Both of my engines are still breaking in but they are both working good.
Paul
I’m building a Hobbistar MK III 60, and I would like to start exploring Gas Engines.
I love the clean look of the NGH-17, and I think it will be a nice installation.
Has this been tried yet?
My next option would be the DLE , but it looks more bulky!
Does anybody know what the Hp is on the NGH-17?
I have been looking at the weight of both 30 oz. without the battery,
12 oz more than the LA 65 that the kit calls for.
This will be my first time for gas and I’m wondering how the vibration is compared to a glow engine.
Should I reinforce the firewall?
The weight issue diminishes a bit when you consider that you can use a smaller fuel tank with a gas engine than you would with a glow. The recommended glow fuel tank is 14oz and you can easily use a 10 or even an 8oz fuel tank with the GT17. Additionally, with the pump built into the carb the fuel tank can be located further from the engine and at a different height. The fueslage of that plane should have plenty of space for the ignition module, etc.. One one plane I moved the fuel tank to under the C.G. of the plane which works out great because then the C.G. doesn't shift as fuel is consumed. On another plane with the DLE-20 Icut a square hole in the bottom of the forward fuselage for easy access to the ignition module etc. and made a rectangular cover that I screwed on.
One of the reasons I purchased a NGH GT17 is that with the beam mounts and front carb it can "drop in" most models designed for glow. Conventional wisdom is to have a firewall that is at least 1/4" thick when running a gas engine. However, as smaller and smaller engines come available I expect to see people becoming more flexible on the firewall thickness.
This gas engine does seem to have more vibration than the Saito 100 4-cycle glow engine that it replaced on one of my models. As a minimum, I recommend making sure that all the glue joints, especially those in front of the wing, are properly glued. It wouldn't hurt to use a little angle stock to reinforce the firewall and other critical intersections.
Enjoy!
Paul
