If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 84
  1. #51
    Join Date
    Nov 2002
    Lahaina, HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RCG 20cc Gas engine
    Thanks for the recomendation,
    I ended up with two of these RCG 20's...because I first ordered a DLE 20 from Hobby King...and the engine went "back order." After waiting five months and many conversations with H.K., H.K canceled my DLE 20 order, and gave me store credit. Hobby King refused to refund my money and believe me I tried for over a month-@!$%& H.K. has a real lousy customer service policy. I had $275.00 store credit, and for $54.00 I could get two RCG 20's. So now you know how I managed to get two of these engines, when I first wanted a DLE 20. I've put the engines up for sale on Craigslist...and any one can have them both for $300.00...shipped anywhere in the U.S.
    The engines came with out a spark plugs...what would you recomend I use, for this engine ?
    Soft Landings Always,
    Bobby of Maui
    AMA 15016
    Hellcat Brotherhood #21
    P-38 Brotherhood #51
    Skyraider Brotherhood #11
    P-51 Brotherhood #76
    Ugly Stick Brotherhood #45
    Say what you mean, mean what you say...and !#$& it if you can't take a joke.
  2. #52
    Join Date
    May 2010
    Harrisburg, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    NGK CM6 available at auto parts houses for approx $4 ea.
  3. #53
    Join Date
    May 2003
    Ocean Pines, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ran new RCGF 20 for another hour today. Installed a NGK CM6 plug before any running. Running 30:1 break in mix with a 16x8 nylon prop. Tached briefly at 9100, transitions nicely, idles fine. Starts were all one or two flips once fuel was to carb. Will change the prop to a 17x9 wood one before mounting in a plane. Next step is to mount it in the CMP Piper J3 120. Leaned the idle and HS needles for best running. No issues at all.
    Jim
  4. #54
    capnduane's Avatar
    Join Date
    Oct 2007
    Moreno Valley, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My RCGF beam mount 20 has been running great in my Sig clipped wing cub. Using a turnigy 17/8 beech prop, and the cub weighs 16 lbs. Using the choke, it starts easily. I'm running Opti-2 oil and regular gas. Have'nt touched the needles! I also have a RCGF 15, but haven't run it yet. Well made little motors.
  5. #55
    Join Date
    Jun 2007
    Egg Harbor City, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    http://www.youtube.com/watch?v=2vni-yJMco8 About a gallon so far,reliable power.
  6. #56
    Join Date
    Sep 2009
    stirling, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Broke my 17 8 jen engine prop today after a dead stick with this engine, opened the high needle a touch and fitted a 17 6 jxf prop got 8400 rpm and flew well for another three flights. Felt that the 17 8 jen engine prop was better for for this engine as gave a bit more speed and mid range on the throttle curve.
    Think my engine is needing another fine tune as a bit gurgly in the low mid range but did not bother today as still running a super oily mix and was in a flying mood not a tinkering mood.
    Also got a 16 8 3 graupner delivered today and was going to try it on this engine but the prop comes with a massive prop hole pre drilled will have to find a spacer for this prop to fit this engine, will post how I get on with that when I get a spacer.
  7. #57
    acerc's Avatar
    Join Date
    Sep 2006
    The Sunshine state, when it's not raining!
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just got in the maiden this morning on a Pica Waco. RCGF 26engine started easily and ran great. Xoar 17x8prop @ 6990 rpm. I only ran one tank in it before takeing flight.I can't see where one could ask for more.
    Robert
    Pitts Brotherhood #2, Cub Brotherhood #3,
    Ryan STA Brotherhood #4, Waco Brotherhood #184
  8. #58
    Join Date
    May 2003
    Ocean Pines, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got my second RCGF 20CC ready to run ... just waiting for a mild day, which may be months away now. . Set the timing, put in a Denso spark plug, and used Loctite on the fasteners. This one will go on a NP YAK 54 120 69.5" (very light). 17x8 9 seems to be the right prop for this motor to keep RPM ~7000 to 7500 RPM. Yesterday (2/1) finally had a warm day. This motor started easily using the electric starter. Ran it with a 17x9 wood prop. Good idle and smooth transition. Didn't try any full throttle yet, but ran it for about an hour. Will tach it and run full throttle next time, and do final mixture adjustments. Now just need the time and space to assemble the YAK.
    Jim
  9. #59
    Join Date
    May 2003
    Ocean Pines, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ran my second RGCF 20 CC for about an hour for the first time today. Totally uneventful. Used the electric starter for the starts. Motor idled fine, transitioned OK and had plenty of power, but didn't run it full throttle yet. This one's going in a NP 69.5" YAK 54, when I find the time and space to put it together. Have a 17x9 wood prop on it and think I'll stay with that for now.
    Jim
  10. #60
    Join Date
    May 2003
    Ocean Pines, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    2x .
    Jim
  11. #61
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys,
    I bought the RCG 20cc from HK around 9 months ago. I got it for my Seagull Model's MXS-R 120. Last week I finally got it running, it took a lot to run this motor somehow the carb was not sucking the fuel out, somehow I tried to troubleshoot it and was able to crank it up. I put a 17X6 Turnigy wooden prop on it. After cranking it up, I cranked up with one flip of chicken stick. The RPM on WOT I almost got 7,900 to 8,000. I like it. On idle I have to turn LSN almost 3 turns then it gives me a decent idle, once again I started it for the first time. I'm using regular gas with Pennzoil's oil not synthetic.
    My question is about LSN, is it normal for new motor like RCG 20cc from HK to run idle on almost 3 turns? What idle RPM is ideal for this motor. Tomorrow I'm, gonna have a maiden of it and I'm excited. I'm posting a video as well as pix here.Click image for larger version.
ID:	1915204Click image for larger version.
    It's great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 XYZ 20, MXS-R RCG 20 (AMA Member)
  12. #62
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mody, if it's running OK, I wouldn't worry much about where the needle is at? It should idle low enough where it doesn't creep on you when you set it down prior to taxiing out for take off. Something in the mid to high teens normally.
  13. #63
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ahicks,
    How are you doing? You always had been great in giving me advices and I truly appreciate that. After finishing up the fuel can with regular non synthetic oil, I will switch it to synthetic. RCG 20 is pretty responsive and I'm sure it would run fine. Idle RPM should be under 2,400 or 2,700 is OK? I'm gonna go to have the maiden tomorrow which is pretty much planned up. I will see how it behaves up in the air. I will give the feedback.
  14. #64
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was thinking idling at 15-1900 is a good target. I would say the maiden will likely show you if or where your carb adjustments are off. Safe bet it won't be right (they never are), so be prepared/keep that in mind during the maiden?
    Best of luck!
    -Al
  15. #65
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Al,
    On first maiden flight, I was taking her off the ground since the grass is so high, turf is uneven had a nose over broke the prop, first Turnigy 17X6 Prop, should have had full elevator but it sux there and I hate it. I swapped APC 17X6 and somehow the RPM were not right I still took off and with full up elevator, it took off as I suspected that nose was pretty heavy and it flew OK since RPM was not like the I wanted, I ended up landing it as nose was heavy she hit the ground so hard that the landing gears came right off the fuse and tail wheel broke too, Thank GOD the damage is not bad, wing tip is slight pushed in but it's in a pretty good shape and I'm repairing it. Tomorrow I will get the coat for it as well and hopefully she should be ready for next week. I have to make some adjustments to the CG as I have push battery packs back in order to achieve the good CG.
    Motor seems to be working good I think and it's good, it needs more lil bit more tweaking on both LSN and HSN and I would pretty much attain the right RPM on it. I'd update ya more.
    Mody
  16. #66
    Join Date
    Nov 2002
    Lahaina, HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys,
    Maybe I just have strong RCG 20, but I'm more then surprised at the performance of the engines. At first (if you read my earlier posting) I was very displeased with receiving the engines (I received two of them). I wanted the DLE 20...but instead received two RCG 20's. Well I put one of them in a Big Stick .60~.90 version and was very surprised at the performance and reliability of the RCG 20cc gas engine. With a Xore 17x6 I was receiving almost 8,000 RPM. I ended up running Master Airscrew 16x10 (price was better and lasted longer for me) and pulled a ten pound model vertical with a vengeance.
    To say I was surprised is an understatement...These are very strong engines and stronger then the DLE 20. I now have flown both engines and I can say with out question...the RCG 20 is one of the most powerful 20cc class engines out there. I have now run both my RCG 20's and both perform outstanding. I use regular "0" alcohol gas with Royal Purple 2 cycle oil. I broke-in the engines on Royal Purple oil mix and gas with no alcohol, and have two very powerful 20cc gas engines.
    Bobby of Maui
    AMA 15016
  17. #67
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bob, I have one of each, a DLE 20 and an RCG 20. Both are well broken in by now (understatement) and they both run APC 17x6 props, turn 8500 (+/-). I think they're a great value, but would not encourage their purchase by a gas rookie. For all practical purposes there's no warranty or support available for them at the dealership or manf. level.
    Looking forward to checking out the new beam mounted 26cc RCGF that appears to be a bored/stroked beam mount 20cc, and have heard there's a new rear exhaust DLE 20 about to come out as well. The 20's have arrived!
    Next will be the 10's, then ???
  18. #68
    Join Date
    Nov 2002
    Lahaina, HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hay Buddy,
    You can buy replacement parts through H.K. or BP hobbies. BP sells RCGF and the parts are interchangeable. I love these little gas engines and my first gas engines. I'm now flying a PTE 36R with wonderful results and moving over to gas engines for all my models.
    Bobby of Maui
    AMA 15016
  19. #69
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yup, you can get parts from Captmicom at Southwest Aerovista Hobbies as well. Captmicom and BP Hobbies both frequently support guys looking for/needing help here as well.
    But they aren't going to warranty an engine they didn't sell, and I wouldn't want to endorse an RCG engine without that warning or do or say anything that might lead anyone to believe that HK provides good support after the sale. It's not that it never happens, but at best it's ultra slow, IF you get any satisfaction from them at all.
    Some of us get that, and order from HK on a roll of the dice hoping for the best. Most of us get that? But it's not something I would ask a gas newbie to subject himself to. That's me though, -Al
  20. #70
    Join Date
    May 2002
    Mandeville, JAMAICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Purchasing RCGF engines from AMR in Canada gets you excellent customer service and a 2 year engine warranty.
    When inverted always remember that down is up and visa versa
  21. #71
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I bought my RCG 20 from HK, cranking it up for the first time was a pain in the butt, somehow it was not sucking in the gas, once it started after that it was one flip and it would fire up. Unfortunately where I'm flying has high grass no club, it's a huge retention pond great area to fly but with my Yak 54 which has XYZ 20cc from VVRC, does not seem to have power as compared to DLE20 but my MXS-R 90 which was nose heavy little more heavy has RCG20 on board, that RCG is a screamer, it can swing APC 17X6 pretty good as well as Turnigy 17X6 which two props I bought from HK, due to high grass and nose over, I lost the turnigy prop now I have one left which I have not tested. Due to heavy nose I landed it so hard that landed gears popped right out off fuse and it's almost done repairing. I will see how it goes. Some how my luck on these planes pretty much screwed up, I do a flight then something happens all the time. I don't know when it would change that I will have at least 5 flights and bring the plane home without any damage.
    Mody
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
