DLE-111 first start... warranty used, but things are looking good.
#126
RE: DLE-111 first start... warranty used, but things are looking good.
The crank twisted when the front 1/2 stopped instantly and the back 1/2 tried to keep going, thats why the rear 1/2 of the case wobbles when it turns over and why it wouldn't turn smooth imediately after the failure. You can absolutely trust the squareness of the case before the incedent, afterward I'm not so sure.
#127
ORIGINAL: BadAzzMaxx
Yep, And DA copied 3W right down to the prop bolt pattern.
Only difference is DA machined the case and 3W cast there case.
Milton
ORIGINAL: karl hibbs
Their tooling, materials, and tolerances is what separates them from, and preventing them from becoming, the best. ( a quote from TOM)
There is not much left considering they got the design from a well known USA engine producer, copied right down to the red heat shrink on the spark plug cap.
Karl
Karl
Milton
#130
My Feedback: (59)
CO
Robert, I am at 5200ft and need something in the 125cc range. When is DLE going to jump DA again so I can get one? Thanks.
#131
My Feedback: (50)
ORIGINAL: az3d
#132
My Feedback: (9)
TX
Here are the promised pictures. I added a bunch to the [link=http://s211.photobucket.com/albums/bb259/wpmcnamara/airplanes/DLE-111%20autopsy/]photobucket album[/link] from earlier. The later images are packing pictures for Robert.
This likely where the large metal pieces came from. It was hard to get a good picture of this. Notice the arc directly above the shaft, from about 11 o'clock to about 1:30. This is actually a gouge in the metal. It corresponds pretty well to the out edge of the outer race of the rear bearing.
The only other place I could find signs of wear was on the corners of the piston skirts. All four corners had similar wear and I expect TOM, Jody, and the rest will say this is normal.
Here is the rest of the series I took of the crank shaft. It's kinda hard to get good pictures without pulling the crank.
The final, end results of the tear down.
I will say, that from taking this thing apart and putting it back together, its pretty hard to get it wrong. Some good hex keys and a torque wrench and that's about it. Taking the bearings out would obviously take a bit more work, but still, well engineered and well built.. A work of art? Nope, but a good work horse.
Engine is all boxed up and going back tomorrow, so you will have to wait for Robert for any more pictures. I would like to thank everyone though as the whole thread and discussion has turned a bummer of a Saturday morning into a decent learning experience for myself. Good comes from bad and all that.
#133
You just learned how easy our little engines are to work on. The hard parts come from the nuances of static timing, electronic timing, port timing, exhaust port heights, squish bands and angles, compression ratios, piston dome/combustion chamber shape relationships, spark plug angles, venturi sizes and flow patterns, reed stiffness. Not all that much really [X(] since those are all design parameters and not something the average user messes with.
You are correct about the skirt corners. Some engine do more, some less, but the piston rocks at the bottom of the stroke if the skirt is long enough to remain well centered. That's about the only place a piston should ever exhibit any wear, and at that minimal.
Pretty soon you'll need to change the name of this thread to one with a happy ending The experience places you miles above the level of the average user. You got the odd one out but what you'll get back will likely be like buying a blue printed engine. I can almost guarantee that Razor Hobbies wants to show everyone how good they are and what the customers should expect should they ever have a problem. This is a good thing for the customers, and for Razor Hobbies since it provides the opportuinity to show who they are. That makes for a bunisess that remains profitable for a long time.
#134
My Feedback: (59)
CO
Robert I think there is a market for a 125cc. The planes keep getting bigger. The 35% Qui Que yak was 102" and considered light, now the 35% are 105" to 110" and weigh 28lbs+. Thanks
#135
ORIGINAL: az3d
Robert I think there is a market for a 125cc. The planes keep getting bigger. The 35% Qui Que yak was 102'' and considered light, now the 35% are 105'' to 110'' and weigh 28lbs+. Thanks
#140
ORIGINAL: Tired Old Man
A new personal level of excitement. Sort of like having sex for the first time...........
Milton
#141
My Feedback: (50)
It's called a BME 116 or 3w-110. MVVS makes a 116 that will pull your arm out of the socket. DA makes a 120. 125cc is totally unneccessary.
ORIGINAL: az3d
#143
My Feedback: (9)
TX
ORIGINAL: Mastertech
I'm still trying to figure out why one would video tape a new engine break in? What was the reasoning?
Tim
Tim
-wpm
PS: Yes, I probably have a bit of OCD or something going on too.
#144
My Feedback: (18)
I have a dle 111 still in the box is there any way to tell which version (new or old) that i have with out pulling the rear housing!!! and if it is the older can i buy the rear housing,new bearing and still use it or did they change the size(OD) of the crank shaft when they upgraded????
#145
LA
I would like to know too. I am looking at buying a 2nd had DLE-111 and wondering if the current version 111 is so much better that i should stay any from the older 111 completly? It runs great.Should i worry about it. Are they that flawed?
#146
There is nothing wrong with the older version case and or cylinder design. The crankshaft bearings were changed at about serial # 650, anything after that is just fine. Even of those engines with serial #s below 650, only a small percentage had issues. You cannot change the version in this thread to the latest version without replacing the entire crankcase, crankshaft, bearings, and prop hub. It's not worth doing and there's no reason to do so. The latest change was made for manufacturing consistancy, not engine longevity/reliability, there is no end user advantage or benefit.
#147
My Feedback: (18)
thanks,jedi!!!!! i'm not gonna worry about it then!!! gonna run it till it dies!!! hopefully for quite a few years !!!!!!
#148
My Feedback: (59)
CO
ORIGINAL: Razor Hobbies
I will have to agree
ORIGINAL: az3d
#149
My Feedback: (50)
Ok got his engine in late yesterday evening I will be going over it today and tomorrow and i will post up my full work up results and pictures.
#150
My Feedback: (50)
I think what tired is getting at is that if anything there are other classes that would be better to approach to fill that class with a gas engine.
Especially when you could complete the engine class by going with a 10cc motor.
