DLE 20 muffler mount dimension
Looking to get a pitts type exhaust for my rcg 20, have found a couple no problem but would like to know if the muffler mount size is the same on a dle 20 as this would give me more options. Im specifically looking for the distance between the mounting bolt holes measured from the middle of the hole. I think the dle 20mountis slightly wider but would be great if I could confirm this, cheers.
My Feedback: (7)
IN
RE: DLE 20 muffler mount dimension
It's 1.29" center -to- center.
Other DLE20cc details plus dimensions are here......
ORIGINAL: a1pcfixer
Recapping the bits & pieces of info on this new engine, here's the
DLE 20cc gas engine details (misc updated info added).......
NEW DLE 20cc Gasser! (Data & Links 1st Post)
http://www.rcuniverse.com/forum/fb.asp?m=9863953
ORIGINAL: a1pcfixer
Cheers mate that makes it 33mm across bolt holes, the rcg is 29 mm across bolt holes so different muffler mount sizes on these engines. Rcgf/rcg pitts it is then.
