Small gassers not worth the investment!
#152
My Feedback: (14)
RE: Small gassers not worth the investment!
ORIGINAL: rangerfredbob
part of the reason nitro makes more power and uses more fuel is because nitro adds oxygen to the mix in the fuel
What you are saying is true, but many do not know that even without nitromethane in the fuel, just methanol and oil can produce more power than gasoline/oil. It has to do with the fact that methanol needs less oxygen to burn well than gasoline, so more methanol (unit wise) is burned than gasoline, which has more power per unit. Confusing, isn't it?
Ed Cregger
#153
ORIGINAL: NM2K
this means that at least two times more methanol (in volume) is burned than gasoline because the methanol BTU per unit of volume is twice the gasoline one,
and it also means that methanol requires half of the oxygen than gasoline, per unit of volume. Right ?
#154
1 Post
its not really confusing. Methanol burns faster therefore you can incease the mass flow per second to compensate for it lower heating value.
The acid test is what prop can comparable methanol and gasoline engines turn at what rpm.
compare a OS 120Ax to a DLe20cc and theres not a lot of difference in weight nor prop rpm...
So is the OS a poorly designed methanol engine or is the DLE an exceptional gasoline engine?
considering the development that has gone into glow engines for RC purposes...
it is true that for small high revving engines methanol was the best choice. That is no longer true. Karting, RC...
#155
Ask Ralph. I am sure he does not agree with that statement as far as racing is concerned. Or go to a racing track and ask about the difference between alky and gas. Same engine, same tune, well jetted, alky yields at least 15% more power at about 80- 90% increase in fuel flow. If taking advantage of the higher allowable compression ratio, power increase is about 20%.
#156
DC
Wnen we were still using carbs and methaol/nitro in our race planes I made the inlet needle hole .086 diameter and doubled the AREA of the other fuel passages...We figured twice as much methanol as gas...A stock G26 will turn 9000 with a Mejzlik 18-6 running gas and 9600 running glow fuel with mag ignition or electronic RC EXL....
We set the piston to combustion chamber distance at about ,020....
#158
TX
PR, doesn't the ignition source of a glow plug powered RC engine limit what can be successfully used. I'm wondering what power limitations are placed on power output when a modeler uses a glow plug on an RC engine. Would not the timing have to be changed in order to really produce gobs of power?
#159
DC
We run glow plugs in our GT80 methanol race engines...11,500+ rpm....19-18 prop..Don't know about GOBS, but fairly strong
Pe's chart shows 20 hp, speed 196 mph...pretty much agrees with radar speed at the races...
#160
ORIGINAL: bgw45
#163
I don't hear a lot of feedback about the Saito FG 14. Did it encounter some problems ?And the Magnum .56 ?Is there a technological limit to small gassers ?
#164
ORIGINAL: Paul_BB
#165
Because the conversion from glow to gas gives almost the same power (the Saito 4s gasser FG 14 is equal in power to the Saito 4s glow .72),
#166
ORIGINAL: TimBle
#167
ORIGINAL: bgw45
I was thinking about those large ignitions on dragsters.
#169
TX
Sport Pilot,
That's kinda what I was thinking. I thought that to get the increase in power from the glow engines you would have to increase the fuel mixture along with having a better way of timing the ignition. But, I'm no engine man for sure.
#170
While you cannot get the timing as perfect as with ignition engines, you can get it close by changine to a hotter or colder plug. Changing the mixture slightly will also change the timing, so slightly rich of peak with the right glow plug will not be far off from the ideal setting.
#171
My Feedback: (19)
ORIGINAL: Sport_Pilot
Those large 44 Amp ignition systems are needed to burn very very rich mixtures of nitomethane. So rich that the power of an elecric arc welding machine is needed. In fact if running dry, that is no fuel going into the cylinder, the spark plug electrodes will melt.
ORIGINAL: bgw45
#172
My Feedback: (22)
FL
I consider myself your average sundayflyer although being retired 5 years an everyday flyer since everyday is fri.sat.and sunday lol.
I dumped all my nitro engines except my satio and os four strokes and and a 0s bgx 1.08....yes I fly alot of electrics and love it.
but I also own and fly a DLE30..the smaller gassers forme fit my budget and the size planes I enjoy to fly..yes I believe the futureis electric as battery technology gets better those sitting on a fence will opt out for cleaner energy .and convenience.but and its a real but...I love gas motors.the dle30 opened up an untapped market and it doersnt take rocket science to see its increasing popularity..
the same goes for the dle20..I am selling my last os 2 stroke 1.08 and purchase a DLE 20.why not.burns gas cheaper than glow fuel.no slim afterwards and gobbs of torque..read model airplane article just out in the latest issue..the title says goodbye to nitro.....sure there will always be nitro diehards and thats fine .why not I did it more than 30 years and enjoyed every minute.
but technology and challenges facing our hobby make electrics platable and small gassers make flying affordable and convenient as well.
#173
AZ
I just wonder if anyone has looked into using piezoelectric transformers to develop the high voltage necessary to fire a spark plug. I understand they are smaller than a magnetic transformer.
#175
AZ
ORIGINAL: Antique
Tried and discarded many years ago by Briggs and Stratton for some lawnmower engines...
edit:
Take a look at this:
http://homelandsecurity.psu.edu/disc...h_voltage.html
Research is going on. Piezoelectric transformers might make real small gas engines practical.
