U.S. - 41 Prop bolt ?
NM
Is the prop bolt for a U.S. - 41 a metric size ? And could you please tell me the correct length that it should be for attaching a spinner backplate. And if at all possible, tell me how to accurately drill the spinner hole in the middle of the bolt ?
Thank you.
Ed
Thank you.
Ed
RE: U.S. - 41 Prop bolt ?
B&B Specialties (http://bennettbuilt.com/index.html) will have your prop bolt, pre drilled and tapped for a spinner bolt. Buy a couple of them. They're not expensive and bend easily with prop strikes.
NM
Hey Ralph; do you have any of these drilled for a spinner up in your neck of the woods ? They need to be 1 3/4 to 2" long to allow for the thick prop washer, and spinner backplate. I can always cut to proper size depending on parts stack. If yes ..... I'll call you soon.
I'm now off to ACE hardware to size the friggin thing.
Ed
Ed
ORIGINAL: Antique
I gotta see a 5/16-24 bolt that was bent by a prop strike
DC
Didn't say I ddn't believe it..I know I'm a 76 year old fart that has been working on Quadras and US 41s since they were Quadra 35s and 40s...It would take a sledge hammer, not a prop strike, to bend a 5/16 grade 8 bolt that only sticks out of a prop hub the width of a prop...There were some US41s that were made with crooked hubs drilled off center...If a US 41 is crooked its likely a bent crank, not a bolt..Us 41 cranks are hard and will usually break if straightened...Been there...
