Seal Orientation
Reply
Old 09-11-2011, 01:07 PM
easyschnucki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Seal Orientation
I am curious to know if the little hole (Puls Port) on the on the (ZDZ Super 80) crank case needs to be completly covered by the seal. Right now it's a tiny bit open and I can hear air moving thru it when turning the prop. From looking at the seal I can imagine that the little thicker part actually (Pic 4) should be facing so that air is only passing thru the little hole on the carb and not behind the seal.
It's the first time that I had the carb off. The engine is basically brand new, less than 30min total runtime. Could that be an assembly failure by ZDZ?
ID:	1660724   Click image for larger version
ID:	1660725   Click image for larger version
ID:	1660726   Click image for larger version
ID:	1660727   Click image for larger version
easyschnucki is offline
Old 09-11-2011, 01:36 PM
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Seal Orientation
The insulator (black piece) was installed upside down. Your picture #5 is the correct orientation.
jedijody is offline
Old 09-11-2011, 02:34 PM
easyschnucki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jedijody
That's what I pretty much concluded. May have been also the reason why this engine took soo long to draw fuel and start....
Old 09-11-2011, 04:28 PM
skip1320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When and where was that engine purchased?Just curious of thin insulator to the thicker ones,thanks
skip1320 is offline
Old 09-13-2011, 04:41 PM
easyschnucki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got it 2 years ago from TBM
Old 09-14-2011, 02:02 AM
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bet your arm was sore!
Tony Hallo is offline
Old 09-14-2011, 06:30 PM
easyschnucki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh yeah. Always reading about the 5-5-1 method. For me it felt more like 50-50-10. Will see how it works out after I turned the insulator around. Maybe all the other users should check theirs as well if they bought it within the last two years.
