STIHL oil ?
RE: STIHL oil ?
ORIGINAL: Brian Smith
You ask him. The old silver surfer.. I would rather hear it from Jody. (smile) Brian
PS hope your well?
PS hope your well?
This goes way beyond what we need to be concerned about inour little toy engines. Unless your running looong flight times, leeeaan mixtures,and continuous150C temps, all you need is a decent to good quality oil that'salmostalways available within 10-15 minutes of anyone'shouse or flying field.
For our toy engines, more oil = more power, cooler temps, cleaner internals. I liketo see some oil on my plane, I like to see some color to it that shows me it's carrying combustion byproducts out of the engine.
TX
RE: STIHL oil ?
All:
I use Stihl Ultra mixed at 32:1 on all of my gas engines to include my echo weed eater. I have been using Stihl Ultra in the following engines with no known issues at 32:1
Zenoah G-20ei
Zenoah G-26ei
DLE-55
And I will use the same mixture in my DA-100 unless someone can convince me otherwise. Jody do you see any problem with me staying at 32:1 on the DA-100? It will be going on my Hostetler Cessna 150 and not be flown 3D. What do you think?
Glenn Williams
Zenoah G-20ei
Zenoah G-26ei
DLE-55
Glenn Williams
sandal (05-26-2023)
RE: STIHL oil ?
Too much oil is bad though. If you go with too much that an engine cant burn the oil then the unburned oil ends up turning to muck. Most oil does get burned if its in a good ratio but if there is too much it will smoke up quite a bit and it will end up ruining the engine.
RE: STIHL oil ?
Link, you would need to exceed about 16:1 before you can say it's too much oil, that's double what we're talking about here.
Glenn, 32:1 with Stihl HP Ultra will never hurt anything and your DA will thank you. Also, FWIW, DA no longer recommends breaking in with mineral oil (Penzoil, Lawnmud), they say to use Redline or Stihl from the first tank, will take them a while to update their manuals and website though.
Karol, Stihl HP Ultra is full synthetic and biodegradable. Stihl HP is a mineral/synthetic blend, not fully synthetic but it's very good oil.
#31
My Feedback: (19)
RE: STIHL oil ?
ORIGINAL: Link119
Now to rattle the cages of the Lawn Boy haters .... and No, I don't use Lawn Boy. But a very good friend of mine used Lawn Boy exclusively for many years in probably dozens of gassers. These ranged from early Quadras to more modern DA products. He always believed in a heavy dose of oil and I'm not even sure he measured it accurately. But he probably ran that Lawn Boy oil at something like 25:1 plus or minus a bit. I still proudly own several of his engines and they are as clean inside as any engine could be and some of them are high time engines. He knew how to tune an engine and the insides showed it. Extremely clean with very little carbon build up and no trace of stuck rings, etc. One problem I did see was excessive carbon in the exhaust systems .... but certainly not in the engines!
While Tired Old Man has certainly never endorsed Lawn Boy oil (quite the opposite actually) he has stated that just about any 2 stroke oil will work in our engines if you use enough of it. My friends experiences prove this statement ... at least for me anyway. Buy a quality oil at a place reasonably close to home, use enough of it and you should be good to go. And thats all I have to say about oil!
#33
RE: STIHL oil ?
How many remember Steen-C which was the first synthetic lubricant I knew of? What a revelation it was to tear an engine down and still see the piston dome clean and shiny! My boss at the kart shop was so excited he said we could eat our lunch using the inside of the head for a plate.
Ernie
Ernie
#34
RE: STIHL oil ?
What most RC people don't know about oils and their impacts would fill a lifetime of research. Trust what Jody is telling you. He, and others, are in a position that provides more information and research data than most of you could comprehend.
Stop seeking some new magical lubricant and use what has already been tested through hundreds of thousands of hours of run time under conditions far more severe than any of you will experience.
#35
1 Post
RE: STIHL oil ?
ORIGINAL: Tired Old Man
Our engines are not wet sump. They are total loss or pass through systems. The oil needs to do its job anD then get out of dodge.
One myth I'd like to clear up is around synthetics. None, not one of the syntehtic 2-stroke oils are actually 100% PAO or XHVI (Group III+ since is derived from Isomerised Slack wax)) base oil. They are all a mix of the aforementioned and mineral oil.
Oil additives are diluted with solvents. The solvents mix better with mineral derived base stocks than with PAO or XHVI so in order to achieve the best all round performance the oil blender mixes around 25-30% mineral oil into a "synthetic Oil" blend.
Hence even for a 2 stroke with a 2 part mix fuel, the oil will participaite in combustion and seldom completely since the oil burns slower than the surrounding fuel and the engine is set slightly rich.
head down to the motorcycle store, purchase the best 2stroke synthetic oil they carry for the motorcycle engines. Go home , mix fuel , go fly.
#36
My Feedback: (13)
MN
RE: STIHL oil ?
ORIGINAL: jedijody
Greg
#39
RE: STIHL oil ?
ORIGINAL: jedijody
crap ive been running 8:1[:@]....
[8D]
#40
RE: STIHL oil ?
Oops. You got that right. How can I get square feet to inches and gallons to ounces mixed up? Thanks for the correction. At least the error was in the right direction. I was always using a three ounce cup so I was getting a 42:1 mix instead. I'll be checking the conversion charts more closely in the future. Dan.
#43
TX
RE: STIHL oil ?
There are tons of oil threads all over RCU. I find it comical that so many are so confused on what ratios to use. It is not rocket science and never has been.
If you purchase a new engine just read the owners manual. If you bought a used engine do some research and find the owners manual online or ask someone who has the engine you now own.
However as I have stated and others have stated. A 32:1 mix is just fine. There are engines that run just fine on 100:1 as well. I know several modelers who run their DA engines at that ratio and they run fine.
Your engine brand may not be able to sustain a 100:1 ratio. My engine (DA-100) can run that ratio. I choose not to go that way as I want some additional lubrication and the benefits the extra oil will provide within the internals of the engine.
A little extra lubrication does not hurt anything and if your engine is tuned properly you should not see carbon build up unless it is an inferior quality oil.
Listen to your engine in flight, It will tell you what it needs if you are attentive enough to know what is going on. The gasoline powered engine can handle 4 stroking but the engine is not happy there. Lean the needles to get the engine on step. If you run too lean it will tell you that it is too lean by either sagging or dying.
Not trying to turn this into a tuning thread but I am just saying that if your engine is tuned properly and you are using a good mix proportional to your engines needs, carbon buildup should bevery minimal ornot occur at all.
Hope this helps some of you who are asking. By the way there are numerous opnions on oils and it is like the proverbial Ford vs Chevrolet debate. That said I have ran in the past the following 2 stroke oils and never had issues except having to tune after switching brands. However I prefer Stihl oil over them all as I (my opinion) is Stihl is just good oil.
Stihl
Amzoil
Red line
Pennzoil
Lawn Boy
Poulan
Echo
Auto Zone brand
Homelite
And some others I cannot remember (no name brands)
I have spent good money on expensive oil and went cheap using parts store 2 stroke oil that was on sale. They all work for my style of flying. I only have one engine that is uncowled and my other planes are enclosed and I have not had over heating issues with any of the above mentioned oils. I run 32:1 exclusively and have never tried anything else. I am sure I could go to a higher ration but why? I go by the old saying of "if it aint broke don't fix it".
These are my opinions are yours may vary. I am not disagreeing with anyone who uses less oil or more oil in their engines. However I can attest to you this in all sincerity. If you are in doubt about your mix. You will not do any harm using 32:1 mix. PERIOD.
Have a great day.
Glenn Williams
Stihl
Amzoil
Red line
Pennzoil
Lawn Boy
Poulan
Echo
Auto Zone brand
Homelite
Have a great day.
Glenn Williams
#47
RE: STIHL oil ?
ORIGINAL: jedijody
I'm changing oils, gonna use rendered Ratfish liver oil at 143:1, makes exactly 1 gallon. Makes my exhaust smell like a tuna fish sandwich.
Seriously, one thing I see time and again in many posts is use of weight measures to reflect volume measurements. A 50:1, 32:1 etc. gas- oil mix is by volume. For 50:1 one needs 2.56 fluid ozs (often referred to "ounces" which is a weight measure and hence wrong).
One should not weigh out 2.56 ounces oil per gallon gas, Rather, should measure out 2.56 fl ozs, a volume measure, to use with that gallon, also a volume measure. N'est-ce pas?
#49
RE: STIHL oil ?
ORIGINAL: OldRookie
So which one would be best for the DLE/DL engines?
Greg
ORIGINAL: jedijody
Greg
#50
1 Post
RE: STIHL oil ?
ORIGINAL: jedijody
Ummmm, a gallon has 128 ounces.
Your formula is correct for finding the right amount for a given ratio but for a 50:1 mix you would use 2.56 ounces of oil to 1 gallon of gas.
128/50 = 2.56
128/50 = 2.56
hmmmm USGallon or Imperial Gallon....
128ounces to a USgallon but 155 ounces to an imperial gallon...
