STIHL oil ?
Old 09-30-2011, 05:28 AM
  #51
MTK
Default RE: STIHL oil ?
ORIGINAL: TimBle
ORIGINAL: jedijody
Ummmm, a gallon has 128 ounces.
Your formula is correct for finding the right amount for a given ratio but for a 50:1 mix you would use 2.56 ounces of oil to 1 gallon of gas.
128/50 = 2.56
hmmmm US Gallon or Imperial Gallon....
128ounces to a US gallon but 155 ounces to an imperial gallon...
Answer.....(drum roll pls).... YES!!
Old 09-30-2011, 05:42 AM
  #52
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
ORIGINAL: MTK
This help?[8D]
[link=http://www.ilovewavs.com/Effects/Music/Sound%20Effect%20-%20Drum%20Roll%2002.wav]Drum roll......[/link]
Old 09-30-2011, 05:44 AM
  #53
jedijody
jedijody's Avatar
Last time I checked, California was still in the USA.
Old 09-30-2011, 06:10 AM
  #54
MTK
ORIGINAL: a1pcfixer
ORIGINAL: MTK
This help?[8D]
APC,
I put the munching deer as my background. Wish the pixelation wasn't so bad....Anyway, got several chuckles out of it from my coworkers, especially during this time of brass renderings at my office. Truly laffable stuff
The recipe Jody gave works fine with any amount of petrol. I know that you know this but for the other readers, stated another way:
Petrol volume you have on hand divided by the ratio you want to run, gives the volume of oil needed to be added to achieve the ratio.
Ex- Petrol / ratio = oil.......lets say you have 2.5 gallons and want to run 32:1 oil mix.....2.5(128) / 32 = 10.0 ozs;
Some oil is packaged in 12.8 oz bottles intended to be used in 5 gallons, to produce a 50:1 ratio
Old 09-30-2011, 06:16 AM
  #55
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
This makes it all so very simple;
[link=http://www.csgnetwork.com/oilfuelcalc.html]Gas Oil Mixture Ratio Calculator.....[/link]
Old 09-30-2011, 09:52 AM
  #56
TimBle
you guys are way toooo serious...
Old 09-30-2011, 10:24 AM
  #57
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
Old 10-03-2011, 09:53 PM
  #58
Ernie Misner
Ernie Misner's Avatar
No one remembers Steen-C, the first? synthetic to hit the 2-stroke racing circuit in the 60's? And man did the Castro R smell good but was a real plug fouler! And what about the good ol' Cheveron white pump premium gas.....
Ernie
Old 10-04-2011, 01:58 AM
  #59
JNorton
JNorton's Avatar
Damn I'm old. I remember all of those.
John
Old 10-04-2011, 04:08 AM
  #60
Brian Smith
My Feedback: (117)
I remember Steen-C. Used to run it in my go cart with twin Power Products engines. Also used "Sunoco" white gas. I didn't know Cheveron had it. . Brian
ORIGINAL: Ernie Misner
Ernie
Old 10-04-2011, 05:02 AM
  #61
TimBle
what's Cheveron?
Old 10-04-2011, 05:23 AM
  #62
w8ye
My Feedback: (16)
w8ye's Avatar
Chevron was a prominent Standard Oil Company of California brand back in the 70's
Old 10-04-2011, 09:19 PM
  #63
Ernie Misner
And their white pump was super high (leaded!) octane gas, not white gas. Racers had to have it. It's understandable that they did not have Chevron stations in Africa though....
Oh yeah, and the Blendzall castor smell had them all beat. You would definitely get high if you got stuck behind someone running that. I think it had an additive that would allow some methanol to be mixed with the gas and remain homogenous. You guys that mix methanol with the gas, how are you keeping them from separating?
Ernie Misner (a past mechanic of Evel Kneivels!)
Old 10-04-2011, 10:27 PM
  #64
TimBle
I know what Chevron is, just not ChevEron...
Anyway to keep methanol in phase with Gasoline mix in a dash of ethanol.
Alternatively, keep the Methanol % below 1.6% or very high around 85%
For anything in the middle a 1:4 parts mix EthOH to MeOH works.
No need to remind you characters of the toxicity of methanol and the age old don't try this at home disclaimer.
Not sure why you want methanol in there anyway. It reduces BTU so you need to richen up the mixture to compensate for power. Fuel economy goes out the window as well. Only advatage is octane but our model airplane engine don't rev no have a high enough compression ratio to exploit the octane so tell me why, oh tell me why
Old 10-05-2011, 03:33 AM
  #65
Brian Smith
My Feedback: (117)
Oh NO. !! The dreaded grammar cops are back. God help us characters. .. ..
B
ORIGINAL: TimBle
what's Cheveron?
Old 10-05-2011, 04:07 AM
  #66
TimBle
Old 10-05-2011, 07:16 AM
  #67
panhndl
My Feedback: (10)
Ok, everyone needs one of these. Stop doing math and just fill to the line indicated...
http://www.motorcycle-superstore.com...uring-Cup.aspx
Edit: Forgot to mention you can probably find one at any motorcycle shop. Been using them for years on my dirt bikes.
Old 10-05-2011, 07:26 AM
  #68
Whistling Death
Whistling Death's Avatar
ORIGINAL: panhndl
You are so right. I have and use one of these, great tool!
Old 10-05-2011, 07:57 AM
  #69
Tired Old Man
Just divide the gas quantity on hand by the ratio. Imperial or U.S. measure doesn't matter as long as you maintain consistent volume types. Imperial may use cc's instead of oz. A simple kitchen measuring cup is usually accurate enough to handle the oil quantity measurement after that. I'll suggest not using your wife's favorite cooking tools though.
Old 10-05-2011, 11:16 AM
  #70
Eganwp
Eganwp's Avatar
I just use my own calculator program I wrote when I was bored at work. :P Allows me way more flexibility in calculation options over all the gas/oil calcs I've found online. Maybe I'll have to share it with people... O.o
Old 10-05-2011, 11:26 AM
  #71
Tired Old Man
A simple calculator is all it takes. However, those tech savvy always have the option of making things more complicated
Old 10-05-2011, 12:30 PM
  #72
karolh
Karol
Old 10-05-2011, 12:43 PM
  #73
MTK
ORIGINAL: Tired Old Man
AKA, posts 38 and 54. It don't get any simpler than that as TOM sez.....
Lessee....a cubit of gas is how much?[8D]
Too much, I know
Old 10-05-2011, 02:00 PM
  #74
Tired Old Man
One cubit...of course
Old 10-05-2011, 02:23 PM
  #75
TimBle
ORIGINAL: Eganwp
jeez wizz, program to calculate volume ratio's....
40:1
How much you want /41 give you the other part.
want 5L at 40:1
5L/41= 0.121
or 121ml of oil
now don't forget to take 121ml from 5L or you will end up wit 5.121L....
darn it even works in US measures, what do you know....
