Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
DLE-111 dies at full throttle- HELP!!
Old 09-30-2011, 10:11 AM
Termites Dream
Termites Dream's Avatar
Default DLE-111 dies at full throttle- HELP!!
I have a DLE 111, 18 months old, about 80 flights on it, in an EF 110" yak. Ran great until a month ago. It runs fine at lower throttle settings but sputters and even dies over half throttle, esp full throttle. It will run fine at full throttle for a few seconds then drops RPM or dies. Here is what I have done so far:
Returned low and high speed needles to factory settings. Adjusted high speed needle both ways in one eighth increments. Richer high speed seemed to help but did not solve problem.
Took off both sides of carb and cleaned out with carb cleaner. Cleaned a little gunk off the filter in the carb.
Attached a new fuel tank directly to the carb fuel nipple to make sure there was no problem with my fuel tank or fuel filter. This made no difference.
I am thinking it is some kind of carb problem. Any ideas? I will send it in for service if I have to; I think I bought it from TBM.
Thanks.
Old 09-30-2011, 10:19 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Default RE: DLE-111 dies at full throttle- HELP!!
Try a different ignition, and battery.
Old 09-30-2011, 10:51 AM
clivemc
your first test should have been the ignition battery - have you tested that? sounds like a poor performing battery that wont deliver the current needed at higher rpm...
Old 09-30-2011, 11:18 AM
Termites Dream
Thanks for the suggestion. Wish it was the ignition battery. Just tested it- 8.2 volts no load, 7.65 volts with a 1 amp load.
Old 09-30-2011, 12:39 PM
apalsson
apalsson's Avatar
ORIGINAL: Mike873
Mike, that is far too high a voltage for those ignitions.
6V max is what they handle
Did you have any sort of a regulator between the battery and the ignition?
If so, what voltage do you get at the output?
Old 09-30-2011, 01:12 PM
Termites Dream
ORIGINAL: apalsson
ORIGINAL: Mike873
I should have mentioned I have Lithium Ions but the ignition voltage is regulated down to 5-6 volts. Would have to get the manual for the reg to see if it is dialed to 5 or 6. Even if it was 6 volts, that should be OK I would think.
Old 09-30-2011, 02:14 PM
Eganwp
Eganwp's Avatar
Did you make sure you properly reattached the diaphram post into the meter lever fork? It's not supposed to simply sit on top or your main jet will be metering too much fuel throughout the rpm band.
It also may be an ignition issue if it just happened suddenly.
Old 09-30-2011, 02:34 PM
Termites Dream
ORIGINAL: Eganwp
Yes, I have put the carb back together twice and I was careful both times to put the metal tab under the fork. If I send the engine back, sounds like I should send the ignition unit in as well.
Thanks for everyone's suggestions. So nobody thinks this is a carb problem?
Old 09-30-2011, 03:04 PM
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
Mike,
Before sending everything back to TBM, read these on testing the ignition;
http://tinyurl.com/65tr8k8
http://www.rcuniverse.com/forum/fb.asp?m=10187833
Old 09-30-2011, 04:37 PM
Diablo-RCU
I'd put a new screen filter in the carb for sure and perhaps a rebuild kit and a new set of NGK plugs.
And Yes, I think it's most likely a carb problem. But, I'm hedging my bet a little with a set of plugs. $20 total in parts should fix you up.
Old 09-30-2011, 04:57 PM
Termites Dream
Thanks everyone, good ideas and links. I will start with a new plug and check the ignition system. I happen to have one of those RC excel ignition testers they sent me free when I got an electronic ignition conversion for a G62.
Old 09-30-2011, 05:03 PM
tande
My Feedback: (48)
ORIGINAL: Diablo-RCU
+1
Old 01-06-2012, 12:50 AM
Termites Dream
AND THE ANSWER IS..............
I ran out of things to look at myself so I pulled the engine off the plane and sent it to Valley View, which I probably should have done all along. They found there was so much carbon inside the cylinders that one of the pistons was sticking. It was easier for them the replace the pistons and rings than clean them. They said it now runs great and is on its way back to me. About $130 plus shipping. I was using Pennzoil air cooled at 35:1, he recommended Stihl Ultra at 40: 1 for a broken in engine so thats what I will use from now on.
I cant speak highly enough about Valley View, they will be getting more of my business from now on. And I didnt even buy my engine from them.
Thanks to everyone who helped with suggestions in this thread.
Old 01-06-2012, 08:06 AM
Antique
Antique's Avatar
"it was easier to replace the pistons and rings than to clean them"
Way to go guys, I guess the cheap price of Chinese parts makes this possible....
I know for a fact that cylinders are about $5 each when you buy 100 or more...
Old 07-25-2012, 08:46 PM
momo123
hey thnx guys. actually i am having exactly same problem with my dla 32 cc. engine dies at 50% throttle or more. i have tried:
new spark plug
needle settings
fuel is coming freely
fuel to oil ratio 30:1
. could teh problem be too much carbon inside too? can i clean it my self with some bare fuel??
pls advise. thanksss
Old 07-26-2012, 03:18 AM
ec121
It will probably take more than raw gas to dissolve carbon.
Old 07-26-2012, 04:22 AM
Termites Dream
I spoke too soon about this engine fix. The engine runs but does not have the power is used to have. I tested and got 16 Kg static thrust on a 28/10. This engine should give 25.5Kg. I changed the timing and seemed to improve a bit (up to 20Kg) but when I flew it the power was worse. The plane flies but its no fun. I have given up. I would like to try the DA 120 but I dont want to buy a new exhaust system.
Old 07-26-2012, 06:00 AM
JRgraham
Well, with new pistons and rings you have to break the thing in all over again, so of course its not going to be the same as before. Its going to take several gallons of fuel to get the thing to preform like it was, again. Give it some run time!
Old 07-26-2012, 08:37 AM
Termites Dream
I have about 8 flights on it since I got it back from Valley View. I have a video of the maiden from a few years ago to compare and it has nowhere near as much power now as it did when the engine was new.
