3w 120 TOC
3w 120 TOC
My brother just purchased a 120 toc edition....... it is supposed to be a higher performance engine used by the original ToC Pilots back in the good old days when Bill Bennet wass alive...... the motor supposedlyt is still not broken in yet.... what prop would be the right size....27x10 28x10? the original owner said it used a 30x10...but i feel its too big.... any first hand users with experience?
how would it compare to DLE111 or a 3w110
My Feedback: (21)
RE: 3w 120 TOC
I'm running a 28x10 Mejlik on my ZDZ 120. The manual states it could swing a 30x10, but I'm thinking like you- might be too big. I've had this engine on a bipe and it's currently on my big Edge. The prop performed great on both airframes. I've always want to try a 29x10, but at a hundred bucks a pop, I'll be content.
My Feedback: (30)
RE: 3w 120 TOC
Hi,
28 x 10 seems to be the right prop. It will turn a 30 x 10 but it really lugs the engine (mid 5000 range)
RPMS for a 28 x 10 should be in the 6000-6500 range.
the 120 is rated at slightly more hp than the newer 3w 110 but if propped for the torque, it will out perform the 110.
hope this helps
Elson
hope this helps
Elson
RE: 3w 120 TOC
my borther just received his motor today....maybe someone can chime in who knows about these older 3Ws.... we noticed the cylinders said made in Italy...i thought 3w were German made all the way?
TX
RE: 3w 120 TOC
I have one of these old TOC 120's and ran a 27x10 or a 28x10. If you use a wooden prop its best to use the 27x10 due to the higher loads of the thicker blade.
FF
FF
TX
RE: 3w 120 TOC
Does anyone know if the new 3w120 uses the same rings as the old TOC 120? I'm looking at replacing the rings in my old TOC and would like to know if there still available.
FF
FF
