How to use the nyrod throttle connection
Reply
Old 10-02-2011, 07:38 AM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How to use the nyrod throttle connection
Being new to gas and coming from glow airplanes, everyone specifies to use a nyrod throttle linkage to connect the throttle to the servo. You know, something like this
http://www3.towerhobbies.com/cgi-bin...&I=LXFU90&P=ML
But I am personally yet to undertsand how this works. I mean, if is there a nylon rod instead of the regular throttle push rod and do the metal push rods screw in both sides? If so, how flexible does it need to be? The throttle linkage on my Phoenix Extra 330s with Dle20 is fairly straight with little or no bend. Can someone explain this system?
Ameyam
ameyam is offline
Old 10-02-2011, 08:01 AM
repinfl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How to use the nyrod throttle connection
I still use metal push rods for throttle BUT I use a nylon clevis NOT metal to connect to the throttle lever on the engine.
With 72 mhz there was a school of thought that any metal to metal conections would cause RF interferance but I do not think
that is such a problem with the 2.4 systems. If you use the nyrod it comes with a short section of all thread that screws
into the the inter nyrod and allows you to use a clevis but again they are supplied with a metal clevis!!! For me the nyrod
is great where the linkage is not straight.
repinfl is offline
Old 10-02-2011, 08:22 AM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So the nylon rod interconnecting rod between the metal bits at both ends?. Actually, I was of the same impression, so I had ordered 12" 4-40 pushrods with the intention of putting ball links both sides. But I have two issues
1) The throttle servo is next to the rudder servo. This is a 60-90 glow airplane that I am converting to gas. So any possibility of radio intererence must be avoided. I am using a 2.4ghz setup
2) The 12" pushrods are not long enough to reach from the throttle to the servo. I could try a coupler or brass collet or something. But it the nyrod is required, thats what I will need to get
Ameyam
ameyam is offline
Old 10-02-2011, 08:56 AM
a1pcfixer
a1pcfixer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your Phoenix has tons of room, so get creative.
Make a new throttle servo mount up near where the fuel tank used to go (while still maintaining access to it),
then mount the fuel tank back closer to the wing tube. Should knock off several inches for the Nyrod (Sullivan)....
...........or 4-40 threaded rod & ball links.
a1pcfixer is offline
Old 10-02-2011, 08:57 AM
K-Bob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For a smaller gasser I would install 256 all thread ( I believe they supply them in the package) in each end of the inner nyrod then use 256 ball links at both ends. Nice and simple with no binding. I would never use plastic clevises.
K-Bob is offline
Old 10-02-2011, 09:22 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its simply an old wives tail that you cannot use a metal push rod for the throttle control even when using 72PPM. What you need to do is avoid a metal coupling at the throttle end. There is no reason to avoid plastic quick links as very little thrust is involved.
dirtybird is offline
Old 10-02-2011, 09:41 AM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have all-threaded 4-40 pushrods with matching ball links. I think the ball links will serve the purpose as there is no metal to metal contact with them- the bit that you screw onto the rod is plastic so there is no metal to metal contact.
On second thoughts, if I simply get some scrap nylon inter-rod from a fellow flier, say 2-3", then screw in 2-56 on both sides with ball links, will that also serve the purpose? Basically, I am trying to avoid ordering internationally due to the expense
Ameyam
ameyam is offline
Old 10-02-2011, 09:48 AM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will this also serve the purpose if get 2-56 ball links locally?
http://www3.towerhobbies.com/cgi-bin...?&I=LXK057&P=9
The Sullivian ones are quite expensive to ship (dont know why)
Ameyam
ameyam is offline
Old 10-02-2011, 10:18 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes that will work quite nicely.
Karol
karolh is offline
Old 10-03-2011, 10:06 PM
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might notice a little change in throttle trim with different temperatures using the nylon rod as compared to steel....
Ernie
Ernie Misner is offline
Old 10-04-2011, 03:23 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ernie Misner
Ernie
Or you may not. I use nyrods for throttle, in most of my models. I've never experienced this problem.
TomCrump is offline
Old 10-04-2011, 05:35 AM
ec121
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like the ball links because they allow me to drill the pushrod hole a little off and the throttle arm doesn't bind because of the angle.
ec121 is offline
Old 10-04-2011, 11:11 AM
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ec121
The bolt-through ball links also will not come off like the snap-on kind might.
Richard
spaceworm is offline
Old 10-04-2011, 05:33 PM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am thinking just moving the throttle servo forward a bit and using standard pushrod with ball link both sides. Should I consider a EZ connector on the throttle servo- you know the one with the screw that tightens on to the pushrod?
Ameyam
ameyam is offline
Old 10-04-2011, 05:55 PM
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ameyam
Ameyam
No, I would not use that kind of pushrod connector for any application. I recommend using bolt-through 2-56 (or 4-40) ball links both ends.
Sincerely, Richard
Old 10-05-2011, 11:09 AM
dogshome
dogshome's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
#2:- Definitely don't use the screw clamp connector.
One thing about straight pushrods and engines:- they work fine with steel balls (heli style ball links) but the brass ball type (sold for aircraft) fret and wear fairly quickly. Useable, but not ideal.
Balls of Steel are what you need!
dogshome is offline
Old 10-05-2011, 12:31 PM
rcdude7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had that problem, this stuff is very sesitive to temp changes despite the BS written on the package, and the longer the length of nyrod, the worse it gets. I now splice in 2-56 rod and just use a small 2-3 inches piece whe I need the extra flexability at the servo and throttle end.
rcdude7 is offline
Old 10-05-2011, 08:42 PM
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm thinking some folks might live in a more temperate climate without the temperature swings.
Ernie
Old 10-08-2011, 09:25 AM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I sourced my LHS and got two things / issues
1) I got 2-56 pushrods and ball links for the same. I am told that 2-56 is good enough for throttle but I am concerned with this ball link
http://www3.towerhobbies.com/cgi-bin...?&I=LXK090&P=7
I think the ball link is too delicate for the job and they dont have anything else in that size. They dont have a bolt through ball link.
2) I was also told that this type of connector on the throttle servo horn will do
http://www3.towerhobbies.com/cgi-bin...&I=LXAHE6&P=ML
I do have nylon nut for this connector so it wont come off the horn but I am concerned that the screw-down will not be sufficient grip. I have used these aplenty on glow planes without problems
Please suggest
Ameyam
ameyam is offline
Old 10-08-2011, 09:33 AM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Only a couple of input points for this subject.
1) Never, ever use any type of E-Z connector on a critical component of a gas engine powered plane. That only invites disaster.
2) Instructions for using a nyrod are included in every package. Read them and continue accordingly.
Tired Old Man is offline
Old 10-08-2011, 11:29 AM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, then should I simply put a z-bend with a retainer on the pushrod on the throttle servo horn side? The avoiding metal to metal contact part is met by attaching the 2-56 ball link at the throttle side. I am still concerned that the ball link is snap on and not bolt through
Look, dont get me wrong here. If I can get it, I will use the nyrod connection. There a couple of problems
1) It costs more to get the connection that anything I can compare. Ordering through tower, if I use UPS shipping, it will cost nothing less than $50 shipping for a $7 item and if I selece USPS there in no guarantee when or if it will come
2) http://www3.towerhobbies.com/cgi-bin...&I=LXFU90&P=ML
isint available till mid Oct
http://www3.towerhobbies.com/cgi-bin...&I=LXFU92&P=ML
is but so far no one has been able to tell me difference between them.
I have in hand 2 Nos 12" 4-40 fully threaded push rods which are just too short. I have 2 Nos 30" 2-56 pushrods but they have one side threading and I dont know how to thread the other. I an not sure regarding 2-56 threaded couplers either because they require soldering (these are available locally, do I use simple electrical solder wire?). Also, the available 2-56 ball links are snap on (http://www3.towerhobbies.com/cgi-bin...?&I=LXK090&P=7) and not bolt through.
3) Locally available pushrods are in mm (2mm, 3mm etc) and there are no ball links available locally in mm sizes.
The difficulties due to non-availability of the parts is basically driving me up the wall
Ameyam
ameyam is offline
Old 10-08-2011, 12:38 PM
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A "Z" bend on the servo end of the pushrod is fine. The bolt through from Tower hobbies of the size and type we have been talking about is Tower stock number LXD912 (Dubro part number 2135). If you click on the double ended ball link on your referenced page and then click on possible substitutions, you will see the single ended Dubro ball links I reference here.
Follow the nyrod instructions as suggested above.
Good luck, it really is not rocket science[8D]
Sincerely, Richard
Old 10-10-2011, 08:35 PM
Valve floater
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just make sure you don`t use all metal to metal. Like adding an extra antenna you don`t want. Serious radio interference.Make sure you do a radio test with the engine running and walk over 100 yds from the plane. Ask me how i know? been there. Almost lost a plane to it. Going to 2.4 was like night and day to help on the intererence issue with me on gas engines.
Valve floater is offline
Old 10-10-2011, 10:09 PM
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Didn't you consder that the chatter from those floating valves could have been a major contributor to the RF interferance?
Ernie Misner
Old 10-11-2011, 03:01 PM
Valve floater
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL. yeah i made that name when i flew only Saito 4-strokes. I would lean it out too much and try to float the valves.
Reply
Display Modes
