OS55, any good?
Reply
Old 10-06-2011, 12:09 PM
skysfallin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS55, any good?
Whats the scoop on the OS 55. I was thinking about trying one but haven't heard much about them either way. Anybody got an opinion.
skysfallin is offline
Old 10-06-2011, 12:16 PM
5150flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS55, any good?
My mom always told me not to say bad things about others, so let me put it this way: BUY A DA60 instead.
5150flyer is offline
Old 10-06-2011, 02:41 PM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For the money spent, he's right. It's not a bad engine, but it generates fit issues not experienced with more conventional carb arrangements, while the power does not quite equal what is available with several other engines in the same size and price class.
Tired Old Man is offline
Old 10-06-2011, 11:03 PM
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
get a DLE 55 rather. Cheaper, lighter, seems to fit many airframes easily and from gauging right arm size, starts easier too.
t
TimBle is offline
Old 10-06-2011, 11:06 PM
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
t
TimBle is offline
Old 10-07-2011, 05:26 AM
skysfallin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't here any overwhelming yeas, so I think I'll stick with the DLE.
Old 10-07-2011, 06:41 AM
Whistling Death
Whistling Death's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: skysfallin
Good choice.
Whistling Death is offline
Old 10-07-2011, 07:03 AM
gade600sdi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I picked up one on sale for $400 odd something. I got it for not much more than a DLE. It is very quality. I have only broken it in 2-3 tanks on the ground but I will maiden this weekend. It do myself like the front carb, as it is easy access and the choke too. I have it in a round cowl Yak. My initial comments are all good, it runs perfect, doestn vibrate, transitions nice, idles beautiful and starts easier than my DLE30. The quality of the machine work and precision is much better than any DLE much better.
Who knows I may not like it once I fly, but I will report back.
gade600sdi is offline
Old 10-07-2011, 12:23 PM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It looks good
SJN is offline
Old 10-07-2011, 04:02 PM
mbinkley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
gade600sdi,
Where do you fly your gas planes in the harrisburg area? I live just out side of Harrisburg.
mbinkley is offline
Old 10-10-2011, 07:43 AM
gade600sdi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I maidened my H9 Carden Yak yesterday. The motor was rough to start I had the breakin 22x8 prop on first and richer oil for breakin and then went with a 24 x8 prop and leaned the oil to 45:1, which I think I need to go 50:1. It was getting smoother last flight with less oil, ran kind of rough with the higher oil mix and sounded rich which I couldnt tune out of it with the needles, the only thing that helped was leaner oil mix. It pulls like a tractor and idles good and overall a good performing engine.
Pro Zinger 24 x 8 @ 6,900 rpm
Old 10-10-2011, 08:39 AM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On second thought, I won't type what I was contemplating for this reply. However, a $600.00 engine using a paint stick propeller, using a break in oil, using a break in prop....
Keep reducing that oil content[X(] They run real smooth up to the moment they sieze up from melting down The oil quantity has absolutely nothing to do with how smooth an engine runs unless you are using too little oil. Whether or not you are astute enough to follow written manufacture directions and tune the engine has far more impact.
Old 10-10-2011, 10:47 AM
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TOM, someone has to keep the manufacturer in business.
TimBle is offline
Old 10-10-2011, 02:01 PM
mbinkley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a link to the OS 55 GT manual.
This mite help you gade600sdi.
http://manuals.hobbico.com/osm/gt55-manual.pdf
mbinkley is offline
Old 10-10-2011, 05:50 PM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From the manual:
Use a fuel with increased oil content and set the needle a
little on the rich side. Too rich a needle setting may cause
misfiring or erratic running due to fouling of the plug.
Use a 25:1 fuel/oil mixture if the particular brand of oil
states 30:1. If the oil states 50:1, use a 30:1 mix. Set the
high speed needle l00~200 below maximum rpm. The low
speed needle need not be richened.
No need to carry out running-in on a bench nor with the
model fixed. Just fly the model with the above mentioned
fuel and needle setting.
A total of 10 flights (5~6 litters fuel) are required.
Avoid prolonged full throttle running at initial stage, and
gradually extend the full throttle running time.
Old 10-10-2011, 08:02 PM
Valve floater
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will it turn the 24x8. Seems like that would be a lot of prop for a 50? Usually i use the 22x8 Zoar. I have a vess prop 22b and i sometimes get overheating issues but it`s darn fast.
Valve floater is offline
Reply
Display Modes
