What IBEC to buy?
#101
I have an ARF "bashed" plane that I built/modified. 70" wingspan low wing aerobatic .60 size plane with a Super Tiger .90 on it converted to run on gasoline. I run both the engine and the ignition off the same battery with no IBEC. RCEXL ignition, Hitec Aurora 9 2.4 ghz setup with an Optima receiver. The battery is a 2200 mah two cell Lipoly running through a regulator. There's not much room in the plane to separate components either. After many flights over the past year and a half, not a single radio glitch...... ever.
(The receiver is the Optima 7 too, not the somewhat better, dual antenna Optima 9 receiver.)
AV8TOR
AV8TOR
#102
AV8TOR
AV8TOR
Good to hear you have no problems.
#106
My Feedback: (29)
AV8TOR
AV8TOR
#107
AZ
When you stick a Lipoly in to an airplane for the receiver you already have lost me. You have already put in the most unreliable battery you can get. Then you stick in a regulator to double your chances of failure.
Good luck . You are going to need it.
#109
I made my own regulator complete with a switch, LED, and a protective housing. I bought the switch and LED from radio shack. The wires from the hobby Shop and the actual circuit board from the dollar store for one dollar. It's a USB charger. I tested it on a test stand for several weeks before putting it on a plane. The housing is 3/4" aluminum square tubing and I milled away all the pockets for the switch. The light bulbs in the picture are drawing 250MH. I have about 30 flights so far with my 53CC XYZ Twin. Hasn't missed a beat.
Larry Kopecky
[email protected]
Larry Kopecky
[email protected]
#110
I switched over to Hitec A9 using the Optima7 and Optima9 channel recievers and have been very happy with the systems performance. One of the easiest TX there is to set up and IMO the best value in high end systems. I first tested it out on a 33% Laser running a no name BEC that came with a DLE 55 I picked up second hand. Solid as a rock.
AV8TOR
#111
AV8TOR
#112
AZ
I'm not too happy about that myself, but went that way after a huge bunch of problems with today's Nimh and Nicad batteries that almost cost me a couple of planes. So I went to Lipoly batts on most of my planes, and treat them with tender loving care. But virtually all my equipment is going to A123 batteries and no regulators, (just a double diode) whenever I can afford it.
AV8TOR
AV8TOR
#113
AZ
Well Zach maybe you should stay off the airplanes I worked as a reliability engineer. 737,757,767 747. I even spent a little time on the airbus A340. But that was on the flight management computer, not flight critical hardware.
Sorry I left out the 777,787, and MD 11
#114
FL
how about let's buy stock? you buy stock in NIMAH AND NICAD tech / companys I'll buy lipo lion A123 company tech.. and we will let the massess debate right and wrong ?
just explain your logic what makes a lipo " the most " unrelabile.. that is a really bold statment
and it is going aginst the techoncaily thats on the market honstly makes no sense why evyething and anything is useing the new battery tech now.. why in the world would the industry do that if what you say is true ?
or are you just full of it ????
and i know my rebutiual to his post is off topic , i'd just like to not see nonsense threads go unchecked
#115
My Feedback: (19)
It seems that someone should post that cute little popcorn munching deer about now!
I've read many posts by dirtybird and find him usually spot on .... but perhaps a bit over conservative at times. I would certainly never consider him diplomatic in his responses and frankly, I appreciate that. As for others, I'm not certain everybody carefully reads and digests posts before they respond. I qualify for that last statement more than I care to admit.
Our hobby is one where at times more than one viewpoint can be right. Its just a matter of purpose and application.
To use or not use an IBEC is one of those areas. For a very long time I was in the "don't use" category but with all the good reports on the Tech-Aero unit, I took the plunge and now own several of them with more to come. I prefer this approach over simply powering the ignition directly (or through diodes) from the flight pack as the T-A unit offers selectable voltage regulation along with current limiting and of course ignition shut off, along with a fair amount of isolation .... all of which are not available with a direct connection.
As for the T-A being less reliable than powering the ignition directly from its own battery / switch ... I question that. Seems that maintaining and even the existence of the separate battery and switch introduces its own failure points. I'll leave it at that and will stay completely away from the battery chemistry debate.
#116
AV8TOR
AV8TOR
#117
My Feedback: (85)
WOW,
I really pulled the scab off this one.
Like I said this thread was not intended to debate the Pro's or Con's of IBEC's but rather ask those using the Ultra IBEC if they are satisfied with their choice 2years after this thread started.
My Talon has a profile type fuse so space is limited hence the desire to loose a battery.
I'd get the popcorn but my wife has me on a diet
Pete
Pete
#118
AZ
I am not into stock-too unreliable for my money. At 86 I need to stick to short term investments
Check this out: http://www.rcgroups.com/forums/showthread.php?t=719116
They use mostly LIFE not lipoly's
or are you just full of it ????Yes I am full of it and proud of it
#119
My Feedback: (19)
WOW,
Pete
Pete
Yes, very satisfied with the T-A IBEC. Would also like to mention something others have not. On small accessory items such as the IBEC, many times the wires are not well secured and strain relieved! Not so with the T-A unit! The wires are well secured with what appears to be epoxy. They will not be coming loose under any kind of normal operation. Well executed construction on the T-A!
#121
FL
have 5 tech aeros all working all worked have had one orange WEC fail .. and it would just stay on all the time .... got it from TBM ..
everyone likes tech aero that I know including myself .
#122
My Feedback: (202)
That was my post from way back before I bought the Tech-Aero IBEC. 42% went "lights out" on me and they sent me another that was DOA. I went straight to Tech-Aero and have never had a problem. I do not believe in using redundant systems and adhere to the KISS theory. Monitor your batteries and radio system and you will not have any problems.
I do not use Lipo on my Rx. I use NiCad due to the high discharge punch offered by NiCad since my ignition is online with the Rx. The IBEC is isolated from the Rx. Redundancy is not needed if you are on top of your game electronically.
AERO-TECH ! Remember it.....rely on it.......trust it!
Most all radio failures happen where within the system? Not the battery, switches, connectors, servos, RF noise, linkages.....etc.
Most radio failures are caused by a "loose nut" on the transmitter!
Flight system? Check it...recheck it....and keep on checking it...constantly.
Just because something works does not mean you don't have to check it.
Flying R/C is always a risk and a gamble. You can not completely eliminate the possibility of a systemic failure but you can reduce your odds of a failure happening. I have put a few holes in the ground in my hobby career but after the dust settles I usually find the reason. Sometimes the reason is my fault sometimes it is not.
The thrill of cheating the inevitable a majority of the time, is what makes life and my hobby interesting.
#123
WOW,
Pete
Pete
#125
I have six Ultra-IBECS in five planes. My B-25 has 2 TA IBECS, 20 servos and 3 batteries. Two of my warbirds have dual Li-Ions and 3 have dual NiCd's. No problems after 2 years of flying these systems. I really enjoy being able to shut off the engines at the TX as well.
