looking for a good 2 stroke gas oil
My Feedback: (19)
RE: looking for a good 2 stroke gas oil
ORIGINAL: raptureboy
AH! HA HA HA HA HA ! AH ! HA HA HA HA ! THESE OIL THREADS ARE SO FUNNY! AH ! HA HA HA HA! JUST PICK ONE! if they were all that bad, do you think they would still be in business? They still make less gunk than a slimy glow, even the worst of them. Ever look at a real plane? how much oil and crap is all over them? Buy a good name brand and your o.k. (The opinions of this poster are not necessarily the opinions of the management or all the other posters in this thread)
This is indeed a funny oil thread and I see a lot of good advice in it.
The OP is trying to choose an oil based purely on keeping his plane clean. I am not so sure it is a good enough reason to decide on an oil, perhaps the link to an electric motor really would be his best choice.
That black mess on the plane is the oil doing its job and taking contaminants such as soot and wear products out of the engine.
Timble is correct, Choose a decent oil that is readily available and use it. I look for Jaso FD ratings but for the OP in this, perhaps Jaso FC would be better as it has less detergent and those wear products will stay in the engine and keep the plane clean.
Proper tuning (which tends to be leaner than most expect, If the engine starts extremely easily and immediately runs strongly when it is cold, you are too rich) will keep a lot of the slime away.
Oil threads have been done to death IMHO.
AR
I use the maxima Premium 2. Very clean, fully synthetic. I break in on the maxima super M. It's a blend and not as clean as the premium. U can find it at your local motorcycle shop.
#31
hehe,,,i was just going to say that my uncles REAL 180 cessnaWAS ALL STAINED AND COVERED WITH OIL,,,,my 450 stearman was totally drenched in 60 wgt ,,,it dripped of the tail feathers after belcjhing out a couple quarts when it was started up....hehe,,,,and these guys want their planes to look scale,,???? i have 123 chain saws,,and 4 other 2 cycl implements and run all on syn,,,40-1 mix,,,i run hell out of them and never had anything but need a new plug ,,,,why all the worry,,? i buy what ever is at the dealer,,,just as long as it is synthetic,,,,,,,,my rcd engines get the same ,,,,40-1 and run hell out of them.
#32
[link]http://www.youtube.com/watch?v=qQGWsV7uUPw[/link]
[link]http://www.youtube.com/watch?v=pE_HbVs3bCM&NR=1[/link]
#33
IL
my problem isn't with the mess thats just a annoyance. my problem lies with a bad choice of oil and a crap motor that now after 2 gallons its finally coming around. just to put this out there i WILL NEVER buy a eletric plane. i would rather leave the hobby then buy a eletric plane. back to what i was origanlly try to get at i'm looking for a oil that performs well with little slugde build up in the motor.
#36
CA
Here is a neat oil link:
http://www.ultralighthomepage.com/OIL/oil.html
I have been using K2 Plus 2-stroke racing pre-mix, from Rock Oil Co., synthetic at 40 to 50:1. That is because bike shop next door to my work has it. I have read tests that indicated penzoil air cooled runs cleanist. I can not find any locally. I have run many kinds of 2-stroke oils and all seem to work about the same. The only exception is real castor oil. The bike shop next-door has it too. It smells real nice, nostalgic, like "race day". It really does gum up the rings. I don't try to run a mixture that is low on oil. I don't see the point. On the contrary a little extra oil will help out with compression. I have never damaged an engine due to oil failure, so far.
Compared to glow engine slime any residue from a gasser is trivial. If you want clean go electric.
I suggest that you do whatever the manufacturer of the engine tells you to do. They don't want to do warentee repairs. What they suggest is what , they believe, will save them money.
I like oil threads! It is fun to read about all the over thinking that goes into such a simple thing.
#38
ORIGINAL: K-Bob
Personally, I use Stihl HP Ultra and have had very good results.
ORIGINAL: armyguy466
won't 100:1 mix burn up the engine
I just started a new job at a Stihl dealer. Have to take some on-line schooling. This included pictures of HP Ultra compared to other oils. Pistons look almost perfect after 500 hours non stop in a BR600 back pack blower.
Ken
PS, in the process of finding out if it is possible to post those photos on this web site.
#39
TN
ORIGINAL: ScottMcM
Any opinions on Evolution synthetic? Looks like Zenoah bottle and oil.
#40
My Feedback: (25)
Penzoil air cooled at 40/1 in all my engines over the years,DA 50'6/60's,zdz40 Da 150 3w 60/75,Dle30,Zenoha G62,26.All run fine,no mess.Never have worn one out,most will crash one before it gets weak.Think of our weed wackers do any of us worry what oil? One of my DA 50's has been in two planes with about 800 12 minute flights.Still runs like new and shows 7100rpm on a Vess 23A.
