Is it OK to use a 6 volt nimh battery for ignition?
My Feedback: (13)
I happen to have an extra 6v NIMH battery and do not have a 4.8 V battery pack (means I have to buy one). I have a DLE 30 CC engine I am installing on a piper pawnee.
Is it OK to use that 6 V battery for the ignition on this gas engine or do I need to invest in another battery pack?
I am using a separate 6V battery for the receiver/servos.
Thanks for responding
Larry
Larry
RE: Is it OK to use a 6 volt nimh battery for ignition?
The ignitions will accept up to 6 volts, anything over that could possibly fry it.
At full charge your battery will be over 7 volts.
Up to you if you want to try it. ?????
Milton
Milton
I have a dle20 ,30 and 55.....all three ignitions are using 6v nimh and i havent had any problems at all. You will be fine.
My Feedback: (117)
Mine run fine on a 4.8 4 cell. The paper work warns you against going over 6 volts and that is just what your doing with a 5 cell pack. I would listen to the guy (Jody) who has worked with this set up more than anyone else. or just risk it at your own expense. Brian
My Feedback: (117)
Can you solder? Take one cell off. I have done it on several occassions. Brian
ORIGINAL: phakur
[font=''Arial'']I happen to have an extra 6v NIMH battery and do not have a 4.8 V battery pack (means I have to buy one). I have a DLE 30 CC engine I am installing on a piper pawnee.
Larry[/font]
Larry[/font]
ORIGINAL: phakur
Larry[/font]
Larry[/font]
My Feedback: (13)
OK Question for Milton and Jody-and Response to ANDY
I installed the ignition system and the battery in the plane. I have NOT fired the engine up but have switched power on and off to the ignition system testing out my optical shut off. I assume that powered up the ignition system with that 6V battery pack. I did not rotate the shaft when doing that.
Would that have fried the ignition??
ANDY: I have the Texas RC Piper Pawneereal close to maidenperhaps two more weeks as I only get to work on it every other weekend.
Larry
Larry
ORIGINAL: phakur
Larry
Larry
Why is it nobody has brought up the idea of using a 1N4007 diode to drop the fully charged 6v NiMh voltage to a level known to be friendly to the ignition module? I thought this was a pretty popular idea? You only need one, a pack of them are available for less than 5.00 at Radio shack, and they're pretty friendly to install if you know how to solder....
GA
wow.. 16 posts and there hasn't been the obligatory.. Your airplane will blow up and you will kill puppy dogs if you don't run A123's??
something has gone wrong....
to the OP..listen to post 2 and 3.
DC
ow, just like the oil debate...The instructions said 6 volts...The acknowledged master of ALL thing iginiion is Bill Carpenter, who has made and tested more ignitions than anyone else on the planet, says more than 6 volts will eventually kill the ignition...Who the @#$%^ are all you experts to dispute his experience ???
Yes, the ignition will work FOR A WHILE on more than 6 volts...Go ahead, but don't cry about it when the ignition quits, IT WILL....[>:]
My Feedback: (13)
OK well I for one am convinced-The 6V pack is coming out to be used in the new Spacewalker I have been eying and a 4.8V pack is going in.
Thanks everyone for the help and insight to someone pretty new to the gas side of things.
And AndyThats a heck of a plane-more than I think I can handle. Good luck.
ORIGINAL: exeter_acres
ORIGINAL: RCFlyerDan
On a quality engines like DA, you can use 6V, but I have had several(3) students try it on the Chinese engines and have fried the ignitions.
I dont fly DA but I'm going to guess they dont make their own purpose built ignitions.
My Feedback: (12)
WI
The ignition module may or may not be able to handle the 5 cell battery. Bottom line - it is designed to work with a 4 cell battery.
And there is no benefit to gain from overpowering the unit. So if you spend hundreds of $ on your plane and engine, why not spend a few bucks on the proper battery.
A while ago I have used an optical kill switch and it gave me interferences, almost lost my plane. After I removed it, everything works just fine and I kill the engine with the throttle, like you do with a glow engine.
I will install a choke servo on my plane, it is hard to reach by when the cowl is installed and I can use this to kill the engine as well. No more optical switches.
