NGH 35 CC Gas engine.
Reply
Old 05-23-2012, 09:09 PM
  #51
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NGH 35 CC Gas engine.
Other NGH 35 here on an Edge 540,maiden flight.Pilot forces engine really hard though,because engine still new.At the beginning pilot is trying to trim the plane to fly like a plane.
I want to remind NGH 35 owners, be careful with exhaust screws,may get loose at flight.Better use Locktite etc.
http://vimeo.com/42705641
Turk1 is offline
Old 05-23-2012, 09:20 PM
  #52
affas
affas's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are my second flight with this engine. Intentionally a bit rich
[youtube]http://www.youtube.com/watch?v=SgBA6Kt6Hic[/youtube]
affas is offline
Old 05-23-2012, 10:34 PM
  #53
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great video Affas.I want to remind again, pls. be sure your fuel line is out of exhaust effect.
Turk1 is offline
Old 05-24-2012, 12:43 AM
  #54
AmishWarlord
AmishWarlord's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Loc-tite gets soft at high temps as on a muffler. Wouldn't some lock washers and heating the bolts up before thighting them do better?
AmishWarlord is offline
Old 05-27-2012, 07:44 AM
  #55
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another video of that Yak 54 with a NGH35 engine. Still new but a couple hours run.
http://vimeo.com/42912786
Turk1 is offline
Old 06-20-2012, 06:45 AM
  #56
SunShyne
Moderator
SunShyne's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
any have any updates? BM has them on sale and I need a 30cc for a project
SunShyne is offline
Old 06-20-2012, 06:58 AM
  #57
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As far as my experience on my friends' engines,they run great.Reliable engines.One needed to change RCEXL ign. unit(why ?? ).
Only user must be very careful on fuel plumbing on side exhaust engines because carb inlet looks towards muffler.You can rely on manufacturer support.
They have liner type cylinder so can be wait for a long life.Prop connection is on the main shaft so no risk of multiple bolt breakdown syndrom.(A 3W throw prop last week during hoover)
Turk1 is offline
Old 06-20-2012, 07:23 AM
  #58
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I normally tighten up the muffler screws, Then run the engine for a while to heat it up good. Then stop the engine and retighten the screws while the engine is hot. That usually does the trick. Sometimes I need to put in a couple of lockwashers for those special cases that occur once in a while. I don't normally use exhaust gaskets as the gaskets seem to allow the screws to come loose. But it is odd that with gasoline engines they don't seem to have that problem as much as the glow engines do. So using a gasket on a gas engine is normally not a problem. I think it has to do with the amount of surface area the mating surfaces on the muffler and engine. Glow engines usually have very little as compared to a gas engine.
earlwb is offline
Old 07-10-2012, 11:20 AM
  #59
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another flight of Yak 54 with NGH35 GT.In fact there were 3 GT35 at field today.One was on bench for break in and you can hear it on background while fast idling after a variable speed running.
3 rd one is on a Sundowner which is still on trimming phase.
[youtube]http://www.youtube.com/watch?v=UjBRdVVEfqE[/youtube]
Turk1 is offline
Old 07-10-2012, 01:28 PM
  #60
Bpar4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Turk 1, The YAK looks like a good performer. Do you have any engine performance data. What prop are you using and rpm's. How much does the YAK weigh ready to fly and was the verticle unlimted? Thanks in advance, Bob
Bpar4 is offline
Old 07-10-2012, 05:10 PM
  #61
michaelchow
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://u.youku.com/user_video/id_UMjc0NDkxODA0.html
michaelchow is offline
Old 07-10-2012, 09:24 PM
  #62
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Bpar4
Hi,those are all of my friends' engines and Im not into gas at all but I will get and make informed you here .As you may notice that Yak has a risky style cowling and I always worry about overheating but my friend doesnt concern at all and never any sign of overheat yet(About 5-6 hours of fly).Also Yak using high oil ratio(25:1) against performance but safety.
Turk1 is offline
Old 07-11-2012, 03:51 AM
  #63
Bpar4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
turk, thanks for the reply. Bob
Bpar4 is offline
Old 07-11-2012, 04:17 AM
  #64
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I just talk to friend and he says,18-10 wooden prop,unlimited vertical.Weight about 4900grs(Pilot RC yak 54).He didnt remember the tach.but I guess it should be about 7500+ RPM s.
Turk1 is offline
Old 07-11-2012, 10:07 AM
  #65
mikes68charger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This motor is getting better with time, seems to be 400rpms over a DLE. I had when throw 2 mufflers before I gave up and drilled a hole in the back 1/2 of the muffler and ran a stud with 2 nuts in the muffler and 1 set of nuts on the out side to help support the weight of this larg muffler.
Mike
mikes68charger is offline
Old 07-11-2012, 08:57 PM
  #66
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike,Mr.Chow is aware of muffler bolt problem and says new bolt system is available now.I guess he uses longer bolts but also I think owner must pay special care when tightening the muffler bolts.(care against stripping and using nord locks for example)
Turk1 is offline
Old 07-12-2012, 02:39 AM
  #67
Citation01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello NGH 35 users. I want to purchase at least one, maybe two NGH 35 engines but can not find any one otther than Apage who has them and they are selling them @ list price. Troy Built had them on sale but on back order, but don't even list the 35 any more. Does any one know where I can get one in the US at below full list price?
Thank you.
Citation01 is offline
Old 07-12-2012, 05:21 AM
  #68
tom_sandiego
tom_sandiego's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check this one out $249
http://www.rcgroups.com/forums/showthread.php?t=1681818
tom_sandiego is offline
Old 07-12-2012, 07:10 AM
  #69
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had ordered and received a NGH 9cc engine from HiModel before. They have the 35cc engines in stock too. The shipping isn't too bad either.
http://www.himodel.com/engines/NGH_G...nvertible.html
This was before Agape and Troy Built Models started selling them.
Uncle George also sells them on RCG too, you could inquire with him about it http://www.rcgroups.com/forums/showt...ight=ngh+engin
earlwb is offline
Old 07-12-2012, 02:23 PM
  #70
FSFLYER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Really like the NGH motors. Have a 25cc....the 58mm made a perfect drop in for a 120 - 140 four stroke motor mount.
Was looking at the NGH 35 to replace a YS 140DZ in an old pattern plane.....unfortunately the thing weighs over 10oz. more than the new DLE 35 rear exhaust that is coming out.
FSFLYER is offline
Old 07-14-2012, 12:57 AM
  #71
michaelchow
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NGH GF38cc 4-stroke gas engine pictures at:  http://www.5irc.com/forum.php?mod=vi...extra=page%3D1
videos at: http://u.youku.com/user_video/id_UMjc0NDkxODA0.html
Old 07-14-2012, 06:36 AM
  #72
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is most certainly fascinating. Thanks for the peek. it is looking pretty good. I almost can't wait to see it in production so we can buy it.
Using a Power calculator spreadsheet, based on your two videos:
20x8 prop,  5,800 RPMs, 1.62 HP, 43.9mph, 8.99 pounds thrust  (70.7kph, 6.61kg thrust)
20x10 prop, 5480 rpms, 1.69 HP, 51.9 mph, 8.91 pounds thrust (83.5 kph, 6.75 kg thrust)
I noticed that the Saito FG-30 gas engine uses 16x8 through 17x10, 18x6 size props, so maybe the 20x8 and 20x10 props that you used, might be a little too large for your engine.
earlwb is offline
Old 07-14-2012, 01:38 PM
  #73
michaelchow
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Earl, thank you so much for your professional advice, The next time, I will make more tests with different props, and flight tests and confirm al details before MP, I hope it will be in market from Sep.
Old 07-19-2012, 04:39 AM
  #74
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Michael Chow, I am curious as to what the third ring groove on the piston is for. If you didn't need it, why machine in the groove onto the piston? Or is there a third ring on the piston? How does oil get to the bottom, camshaft area, valves etc?
earlwb is offline
Old 07-19-2012, 06:07 PM
  #75
michaelchow
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Earl, first ring is pressure ring, second ring is oil ring, they are with different shapes and functions. third groove idea is from glow engine piston store some oil and dirt while engine running.
made a solution for supercharging and lubricating, there are two nipples on INTAKE MANIFOLD, and two nipples on Back cover. need be connected with pipeline.
Two nipples on Intake-Manifold: one is no pass to intake-manifold but pass to Walbro carb, one connection from back cover, so the pressure from crankcase to carb via this nipple to supercharge.
one nipple is pass to intake-manifold and connected from another nipple on back cover.
So, when piston move from TDC to BDC, the pressure from crankcase boost to carb and manifold via two connections.
when piston move from BDC to TDC, the negative pressure from crankcase will suck gas mixture to crankcase via the another nipple connection (not from carb connection nipple, one-way), to lubricate the roller bearing, and there is a hole inside the crankshaft, the oil transferred into cam gear for lubrication via this hole.
when engine running, the carb will pump twice for each cycle, one is effective pump, one is noneffective, and now make second noneffective pump to send oil to crankcase for lubrication via the seond nipple on manifold to second nipple on back cover.
I am sorry it  is hard to explain with my poor English.
Reply
Display Modes
