Syssa Troubles...SOLVED!!
HI
Well I recently sent my Syssa engine in to SAP to have them look things over. I was having a difficult time getting the idle below 3000 without it dying. It was also very difficult to start. The engine sings very nice when it is running and I was getting 8600 with an 18X6 prop up front. The trouble was getting the idle below 2500 as Syssa recommends 2300 idle rpm. At 2500 my plane was moving quite a bit while on the ground.
Sent it in to Todd at SAP to have them look over it as several of my friends tried to help me get the engine started with not much success. And idle below 2500 was very unreliable. Todd got my engine and started to look at it. He said that my engine was running perfectly but that it was on the rich side, nothing was wrong with my CDI neither. Had him install a new choke, because the previous owner had trouble getting it to seat well so he removed it and lost it.
Todd sent my engine back to me, so I figured alright my engine is goood to go. Got everything installed, even put all new fuel lines checked all my filters, got some new fuel mixed and went to the field. Had difficulty starting it again with the needles set by the guys at SAP. Kept trying and finally got it to start, let it run at around 3000 for a little while to warm it up. Throttled up to WOT to check the high, again the high was sounding great at 8500+, but as I brought the throttle back down it would die out at around 2800 or so. Again had difficulty getting it started, actually killed my starter battery.
I just don't get what is wrong with my SAP after it was looked over by the guys at SAP. I will try some more and see if I can get it to idle reliably and start easily like the other Syssa's at my field. I would have thought that once I got it back it would be running reliably, but it hasn't been a very enjoyable experience. Any thoughts guys on what could be wrong? Maybe I need to get an overhaul kit fir the carb?
Aloha,
Les
Aloha,
Les
RE: Syssa Troubles...SOLVED!!
It sounds like your low end is lean. One way to check is to get the engine idling as low as it will hold a setting then suddenly increase to full. I suspect that it will die lean. Richen the low end until the engine accelerates instantly
This is a simple engine to run well. About as simple as they get. Learn to tune it better and you'll be much happier and so will your engine
CO
ORIGINAL: molokaiboy
Sounds like he anwered your question. Take w8ye's advice and tune that engine up correctly, get some help if need be.
DC
Go read the story on the other forum...It was already sent back and returned...
Confused ? Surprise, surprise... One poster here says rich, the other lean.. Since it starts and runs, then dies, it's a pulse issue...Find the leak, it will work....I M N S H O....
HI
Didn't like the answers on FG ?
Are you just trying to start trouble for SYSSA?
I am in no way bashing SAP, I am just stating facts that apply to my situation.
Aloha to all the guys that have posted helpful info.
Les
I would pull the engine out of the airplane and run it on a test stand.
with it out of the plane, everything is out in the open for easy access and observation.
So then if it runs great on the test stand, then you have a problem with the airplane then and not the engine.
the SAP folks test ran the engine on a test stand too. So it ran Ok there for them.
That alludes to you having a problem with the plane, maybe the fuel tank and fuel lines or something.
HI
Well got a chance to try the new fuel tank. As suspected the new tank solved nothing, still did the same thing as all previous attempts.
So we got an idea, we removed the low needle, and with the ignition off applied an electric starter and spun it over hoping to see fuel spit out where the needles was. Nothing came out. We then closed the choke opened butterfly to WOT and applied an electric starter again with the ignition off. All of a sudden some dark black crud along with fuel came flying out of the muffler. It seems that there was oil gummed up blocking fuel flow. We gather the fuel all evaporated and left behind just the oil and crud that blocked proper fuel flow.
Well we finally got the engine started and it ran well after some tuning. It still seems to be running a bit on the rich side on low throttle (2400-2500). High is still on the rich side as well and I had 8200 with an 18x6 prop. Will do some flying and minor adjustments as needed till it breaks in a little more.
After going through all that to get it running, I am wondering how they got it to run well during their tests, and I had such a difficult time. No one will ever know I guess.
Thanks to all the guys that gave their advice.
Aloha,
Les
Aloha,
Les
1 Post
a few possibilities
1) ...perhaps they never ran it at all... <shikes, controversial>
2) ...perhaps the bloackage was in your fuel lines before the carb? DO youhave a fuel filter on? Eithe rway of they connected it too thier plumbng and it ran then the blockage was somewhere in your fuel lines.
HI
Second tank, new with all new fuel lines, no filters, pressure tested, fuel moving correctly. I don't think I had any blockages in my fuel lines. But the good thing is it is running now.
Thanks for all the help,
Les
With no fuel filter over time you will keep having nothing but problems. The passages in a gas carb are much smaller than in a glow engine and will block easily. The best is to use a Walbro felt type filter for a cluck in the tank and use a third line for fueling. For extra protection it is good to have a filter in your gas can as well. Do not even bother with using a metal screen type filter (Dubro, Trax...) as the screen is too coarse to do any good.
HI
I always use a filter on my fueler tank, also inline filter from tank to carb, filter on vent lines. I just removed the filters to assure I wasn't getting any leaks at my filters going to the carb, as I had that happen previously, thats why solid lines were used just for testing purposes only.
Aloha,
Les
Aloha,
Les
You missed Super08's point completely. The filters you have been using are useless. Dump the glow mentality and use products designed for use with gas engines, not those intended for glow engines.
I'm not buying a word of the comments you made about crud puking out of the muffler. Not a way in hell the carb would have pressurized enough to push crap out of the muffler, and no way the muffler had anything at all to do with fuel flow. Perhaps you had stuck something into the muffler that was finally pushed out?
Perhaps you just wanted to move on and not let anyone know where you had made a mistake?
HI
As for the crud not coming from the carb you folks may be right and I may have worded it incorrectly or explained totally wrong, for that I appologize, but there was definately something causing a blockage. But wouldnt fuel come out at the needles when we removed it?
I have a felt type fuel filter clunk in my tank but the previous owner did not, so we may have flushed some things that accumalted while he had it.
OK it may have not flown out but it did kinda just spat out. Whatever we did worked and that is just great for me. Now I can get flying.
