*Mintor 33cc & 38cc Gasser*
My Feedback: (10)
I'm in the market for a gasser for my new Rascal 110 that hopefully will be coming in around Christmas. I had the original Rascal 110 with a G26 spinning a XOAR 18X8 prop and it just didn't have enough power to hover the Rascal. I have been looking at the DLE 30 which I had on a H9 Taylorcraft and the Mintor 33cc and the 38cc at [link=http://www.topdawgaviation.com/]TopDawag RC[/link]. The Italian made engines are some of the finest but I can't find much about these engines. Just looking for some input. Anyone running one of these engines?
RE: *Mintor 33cc & 38cc Gasser*
ORIGINAL: Zippi
Zippy, my old friend ! The 38cc does not weigh much more than the smaller engine. I am sure you will like it. Let us know how she runs.... Capt.n
My Feedback: (10)
ORIGINAL: captinjohn
How's the 202 doing? Sig is finally releasing the "new" Rascal 110 just before Christmas so since I lost my other one due to TX problems I have to try another one. The last one had a G26 from Ralph C. swinging a XOAR 18X8 and it just wasn't strong enough to pull out of a hover. I'm probably going to get another DLE 30 and swing a XOAR 19X8 prop but boy do those Mintor engines look nice. I like the Italian made engines. Good quality and design. The Mintor 33cc Weighs 2.1 lbs and the 38cc comes in at 2.2 lbs vs The DLE 30 at 2.4 lbs. I don't think the 38cc is available in the US yet but the 33cc is.
My Feedback: (10)
ORIGINAL: ultra6a
Take a look at my new Mintor 38!!!!!
ORIGINAL: Zippi
Turning an 18x10 apc in mine but have a 19x8wide blade that I will run this weekend.
Extremely easy to start and run. Choke on, full throttle, ignition on, flip twice to pop...down to low throttle, and choke off, takes 2 flips. The needles are set at 1 3/4 for both and that's about right for the first several runs
My Feedback: (27)
NC
ORIGINAL: Zippi
That 38 looks like a piece of art. What prop are you going to run? Can you give me a dimension from the center of the crank to the most outer part of the muffler. I want to see if I can fit this inside the cowl of a Racal 110. Thanks.
ORIGINAL: ultra6a
The dimension from the center of the crank to the most outer part of the muffler is approixmately 3 inches.
My Feedback: (10)
ORIGINAL: ultra6a
ORIGINAL: Zippi
ORIGINAL: ultra6a
ORIGINAL: MTK
Yes I am running the 38cc. Nice looking engine but powerwise it's just okay. I have mine piped and getting about 500 rpm boost compared to stock muffler. That muffler is extremely loud BTW, nothing more than a noise diverter.
In my set-up the carb actually sits inside the rubber isolator. Just enough clearance for the needles. Stand offs are 3/8" hex ally from Mc Master Carr and the 2 1/2" length worked great in my set-up. Half the weight of the stock set
ORIGINAL: airraptor
any one run these yet?
It's easy to start, transitions well but has only a moderate top end. Maybe it will improve with several gallons run through it but it turned an 18x10 apc at about 7200 and a 19x8 wide blade apc at around 7000. When you consider my SAP 180 ran the same 18x10 apc prop at 8300, the engine has a long way to go. Except the SAP180 couldn't turn the 19" prop.
I am hoping the Mintor 38 will turn more prop at 7K rpm in the long run, but will see on that one
ORIGINAL: airraptor
well that doesnt look to good stock. but on the up side maybe the timing is all messed up and i can work on it some. i do like the look and price of the Mintors but power on the 38 is just above a 120AX......
I will eventually raise the exhaust timing too (about 1/16" or around 10 degrees) which should improve the boost from the pipe.
But it is a gorgeous engine with very good throttle response up to mid range. From about 2/3rds throttle to full, you don't get much difference in power which means the engine is not ported as well as it could be.
