Gasoline Clunk tube?
My Feedback: (204)
RE: Gasoline Clunk tube?
ORIGINAL: RJConnet
a1pcfixer, Have you personally experienced this or are you just repeating the conventional wisdom on this matter. Several years ago on the first really cold day of the winter the clunk in my plane stopped clunking, it was stiff as a board (tygon). I had some of the Dubro neoprene in my drawer so I cut off several inches and placed it in a jar of my fuel. After five weeks it was still like new so I replaced the clunks in both of my 50 cc planes. It is now 2+ years later and I have not seen any sign of deterioration, no problems of any kind. Maybe the ethanol in Oregon is not as potent as the stuff in you area..........RJ
ORIGINAL: a1pcfixer
I believe they are callimg it neoprene but neoprene is that black hose mainly used for windshield washer fluid. I think this black tubing sold by Du-Bro is actually called "Buna" which is gas compatible, in which Neoprene is not
That's neoprene...very, very bad!!!!
If it hasn't (yet) deteriorated, it most certainly will!
Do NOT use neoprene with your gas!!!
Tygon, Oregon, or Viton are the accepted brands to use with gas!
ORIGINAL: Clay Walters
This seems to work fine too.
http://www3.towerhobbies.com/cgi-bin...P?I=LXD735&P=8
All he wanted was a simple answer Like someone said neoprene has been fuel line in cars for years, however the alcohol seems to have some adverse effect on some types of neoprene. The Tygon type line seems to be what most small engine vendors are going with and works well, but it does get stiff after a while if it is not submerged in gasoline continuesly. I just purchased 100' of 1/8" Tygothane for $27 from a supplier on ebay. That should last me for a while I'm splitting it with a buddy of mine. I have found that the bronze sintered filters work fine and are easier to get in the tank if your using a smaller tank, for smaller gas engines like the DLE 20. http://www.ebay.com/itm/100-Ft-TYGON...item1e689231cb
My Feedback: (24)
GA
The line that comes with the Fortitude tank is great. It will not slip off. You have to cut it off once it is installed.
I love their tanks. It's all I use now.
http://www.3dhobbyshop.com/Fuel-Tanks_c_755.html
ORIGINAL: Hill202
#31
Can't say that I would blame that crash on the tank's clunk, as that sort of flying requires special needs, and having a proper length clunk would in my opinion be one of those needs, plus in a transparent tank the obviously short original clunk line was there for all to see.
Karol
Karol
#32
ORIGINAL: karolh
Karol
Karol
i read on F G about those tanks,, apparently several people have complained about that issue, and also the cap being glued on.... the bottle is made of such thin plastic hardly any force can be applied with out ruining it
#33
My Feedback: (204)
ORIGINAL: MetallicaJunkie
true good point there... he called the shop he ordered it from and they assured him that it was normal...
ORIGINAL: karolh
Karol
Karol
#34
My Feedback: (7)
IN
i beg to differ, my brother crashed because of a piece of chit Fortitude tank.... look at the clunk.... not good for hovering
My issues with their tank was solely with their shortest 8 ounce units, which I wanted to try with one of my 2 DLE20's
Here's my review I posted on their tanks;
"Std size Tygon in longer tanks is fine, but in this short 8 oz tank, such does NOT allow such a light clunk to properly settle to bottom. A Poulan clunk/filter part # 530095646 has the weight to do the job correctly. These tanks don't need so much sealant just to keep the cap on (no leaks). A smaller amount is sufficient. I nearly collapsed the tank trying to remove the cap. Also, zip ties on the clunk line is needed as gas will cause Tygon to swell and drop off. This is a new product line for you, and as such there's bound to be growing pains. Hopefully the above issues will be corrected for an improved product line." {none of which has as yet been corrected}
On such short tanks, std Tygon is too rigid to use with a light clunk.
Oregon [part #07-266] .094" I.D. x .203" O.D. [wall thickness=.050"] is a far better fuel line for short tanks.
Oregon part #07-266 is what we need inside the fuel tank, connected to the clunk.
This one is far more flexable than std Tygon, and combined with the heavier clunk in the included photo, will do a superb job!
About the 3 fuel line photo;
A=Oregon [part #07-257] 1/8" I.D. x 3/16" O.D. [wall thickness=.035"]
B=Oregon [part #07-266] .094" I.D. x .203" O.D. [wall thickness=.050"]
C=std Tygon 1/8" I.D. x 1/4" O.D. [wall thickness=.060]
Do NOT use "A" in our models, as it's waaay too thin, and designed for chainsaws, weedeaters, and such.
"A" is the thin wall style best used with the tiny Fortitude felt clunk.
Again, my comments were directed solely at their short 8 ounce tanks. Their longer tanks may be fine.
#35
My Feedback: (24)
GA
ORIGINAL: Hill202
Yeah, but the line did not slip off [8D]
#36
OK
Try this, its clear, stays flexible and its only about twenty eight cents a foot. I'm switching over to it, a friend of mine runs it with no problems. Here's the scoop from the manufacture,
Tygothane® Formulation C-210-A
Our rigidly controlled manufacturing process makes Tygothane® Precision Polyurethane Tubing the flexible polyurethane tubing that has consistently tight tolerances from lot to lot. Precision tolerances and high elasticity provide the user with an easy, worry-free attachment to fittings. Made of a tough, ester-based polyurethane, Tygothane Precision Polyurethane Tubing's clarity, high tear strength and excellent abrasion resistance make it ideal for many applications, including fuel and lubricant lines, pneumatic lines, abrasive product transfer and cable jacketing. It also offers exceptional resistance to oils, greases, fuels and many chemicals.
Able to withstand rugged daily use, Tygothane® Precision Polyurethane Tubing resists weathering and can be safely used in temperatures ranging from -100°F (-73°C) to 200°F (93°C). It meets FDA criteria for food and beverage use and is also available in ether-based, medical grade and reinforced formulations.
#38
My Feedback: (204)
ORIGINAL: michajon
#39
MO
ORIGINAL: karolh
I have found that keeping the tank partially filled with gas helps to keep the in tank Tygon plumbing lines flexible for a much longer time than when the tank is kept empty when not in use.
Karol
Karol
from the last flight and the line stays like new.
Tim
#41
skillet
mcmaster and grainger both have tygon
25' spool is about $150, with about $20 in shipping = $7/ft. You can plumb a gasser with 1.5 ft = $10
I have viton clunk to carb in my gassers, but the vent lines, fill lines, etc are tygon
#42
Ive use the Hayes tubing for 5 years now and haven't had any issues with it
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXK824
