To big? or not big enough?
Hello, I'm currently weighing my options for building a 1/4 scale Albatros DVa. My question is a US engines 2.5 41cc to big or not big enough? I want it to fit in the engine compartment aswell. Any thoughts or advice would be greatly appreciated. Thanks Ken
NC
RE: To big? or not big enough?
It should fit and your going to need the nose weight. On the other hand, the Alby has a huge spinner so you might want to consider a more powerful engine to swing a bigger prop. Great choice of aircraft, good-luck.
After thinking about it a bit, the DLE 30 might be too small. The prop I'm using is 18x10, a 20x8 would probably work too. Prop size might be the big issue on an albatros, not sure how big a 1/4 scale would be. I buy my DLE's from Vally View RC. Even though I havent needed it, their service is pretty good.
Edwin
Edwin
CA
I have one of their 1/4 scale d-7s. Watch the weight in the tail. Do not beef anything up. You will need to add weight to the nose. I ended up adding 7-pounds. I seriously doubt if yours come out at 14-pounds. Their literature is very unrealistic, I assume that is where you got that number. My guess is it will come out 20+ pounds.
I have flown three engines in my D7. First a 38cc Efco chainsaw conversion. It used a 22x6 prop. It flew fine, seemed like a good match. It started running sickley so I change it out. Second, a 50cc Echo chainsaw conversion. Lots of extra power. I think if I were not carefull I could have folded the wings with this one. I now have a Zenoah G-38 in it with a muffler that has huge volume. It sounds cool. It flies great. It has a magneto so no more batteries to charge for the ignition. It does hand start easily. This is probably the best match. The BUSA tech guy recomended this engine to me.
If you are still shopping engines, I suggest you try to find a used G38. They are cheap, some folks think they are obsolete. They are not! These old engines are bulletproof. The parts are cheap when needed. They weigh more than more modern designs but, that is an asset for this application. They are as reliable as it gets. IMHO the perfect engine for a 1/4 WW1 plane.
WY
The US 41, (Quadra 41, Reids Cheetah 41) and the G38 are all in the same power, weight and smoothest class. B bit heavy, modest power and a bit vibratie. BUT they will last the rest of your life with only gas/oil, the occasional spark plug and carb kit.
