Engine noise
Old 04-03-2012, 06:50 AM
airega1
My Feedback: (204)
airega1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engine noise
Hey wait a minute! Where's the lugnut that should've chimed in to say" get rid of those ignition problems go electric"
airega1 is offline
Old 04-03-2012, 07:03 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There's any number of things that could be causing his problem.
I'm saying that following the so called installation guide lines that have been around longer than 8 track tapes, aren't required for 2.4 installations.
While I personally wouldn't mount my ignition module on top of the receiver, I also wouldn't worry about a battery, switch, or wire, being too close by the reciever or ignition system wires.
Personally, I'd be looking at vibration or a bad connector.
BarracudaHockey is online now
Old 04-03-2012, 08:17 AM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Andy, Here are a couple of emails I got from Jr and Hitec in 2011 well after the eight tracks were no longer in use. Dan.
ID:	1746313   Click image for larger version
All Day Dan is offline
Old 04-03-2012, 10:44 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Dan, I know your feelings on this.
I realize you recieved them after 8 tracks went out of fashion, I'm merely saying they were written or based on philosophy from then.
Old 04-03-2012, 11:10 AM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dirtybird
Its interesting that in my 50+ years working in the RF field I never heard of an RF leak. I guess I will have to add that to my vocabulary.
The OP does not define what he is seeing. We don't even know what he is getting but several have jumped in and repeated the old school fixes none of which works.
There is another problem caused by a running engine. Its called vibration. It could be causing what he is seeing. But then we don't know what he is seeing so maybe we should not guess about that either.
Another problem with a running engine is the sound pressure it generates
When trying to fix a problem we should first identify what the problem is.
Hmmmm... well I've been at this RF game for more than a few years myself. And I have seen plenty of so called RF leaks! Maybe you've never had to track down serious internal interference at at a transmitter site that was caused by one loose RF connector? Or how about intentional RF leaks from a radiating coax. Or how about RF leaks from a bolt together cavity that just had poorly torqued bolts? Or any one of dozens of other so called RF leaks I could think of. So yes, they do exist.
There is constant mention that 2.4 GHz. is immune to ignition noise .....and for the most part I agree from an RF standpoint. But what about the back door ... ignition noise that can enter the radio through the servo leads or on the power leads. This can still exist regardless of the frequency of the radio.
There have been quite a few threads over the years about Fuji ignition noise problems and a known authority ..... TKG confirmed this in this thread. But some people just have to dispute this. Replace the dn junk Fuji ignition with a known Rcexl one and be done with it.
Truckracer is offline
Old 04-03-2012, 11:16 AM
  #31
tomfiorentino
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BarracudaHockey
IMO unless one is very familliar with RF and antenna function he should not suggest against techniques that have been proven for the past decade.
How about 20 years working on radios, avionics, onboard computers, weapons systems, and radar systems on naval aircraft and teaching network cabling and troubleshooting at a major university?
Yea...but did you sleep at a Holiday Inn?
tomfiorentino is offline
Old 04-03-2012, 02:25 PM
  #32
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, but I did sleep at a Holiday Inn EXPRESS. Me smart - TeHeHe!
Jezmo is offline
Old 04-04-2012, 04:37 AM
  #33
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: tomfiorentino
Yea...but did you sleep at a Holiday Inn?[:D]
Actually yes, this weekend at Sun-N-Fun
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
