Electronic ignition verses magneto
Old 04-01-2012, 05:03 PM
comanche260c
Default Electronic ignition verses magneto
I have a zenoha g38 and went to start it today. No spark so i pulled wire out from both ends and clipped it back so it made good contact on both ends.Magneto end where it slides in hole and spark plug cap end. Well now it to short so can i replace it with a car ignitionwire or what? Or should i just update to a electronic ignition set up for $70.00. I called and priced out a new magneto and they were about same price. I wonder if its better with a electronic set up ??????????
Old 04-01-2012, 05:14 PM
vertical grimmace
vertical grimmace's Avatar
Default RE: Electronic ignition verses magneto
Personally, I am trying to move most of my warbirds to Magnetos. It is less to worry about. Too bad yours is messed up. E-ignitions are easier to hand start, but I use spring starters on my magneto engines.
Old 04-01-2012, 05:25 PM
w8ye
My Feedback: (16)
w8ye's Avatar
You need the ignition wire that has a wire core.
The normal car wire is a grphite string for a core
Old 04-01-2012, 05:41 PM
comanche260c
where can i get that wire core wire
Old 04-01-2012, 06:35 PM
btflycrazy
i would go to your local small engine shop and see what they can do, and to get your g38 to start a lot better set the mag. at .002 and sand down the flywheel mine starts on the second flip every time
Old 04-02-2012, 03:40 AM
w8ye
My Feedback: (16)
w8ye's Avatar
The high tension spark plug wire for these small engines is 5mm whereas automobile wire is often 8mm diameter.
Old 04-02-2012, 05:49 AM
BarracudaHockey
BarracudaHockey's Avatar
That spring starter scares me
I converted my GT80 to an EI from RC Extreme Power. I love it, 3 flips to pop, two flips to run.
Old 04-02-2012, 07:14 AM
btflycrazy
this would be a cool factor for any rc plane if yours can deal with the extra weight
Old 04-02-2012, 11:45 AM
ec121
I bought a new mag for my Quadra 40 from the magneto manufacturer instead of an RC supplier, and it was half the price of a catalog house model. I got lucky, and it had the maker and model on the coil.
Old 04-02-2012, 03:23 PM
comanche260c
does a electronic ignition give a bigger spark than a magneto would give
Old 04-02-2012, 05:12 PM
Truckracer
My Feedback: (19)
ORIGINAL: comanche260c
Hard to say but I would give the edge to the EI. Magneto spark depends on so many factors from the condition of the coil and associated parts, RPM, coil to flywheel gap, etc. Old magneto coils seem to just get weak with age. Seems that so often old lawn equipment and saws have weak spark but to be fair, an EI of the same age probably wouldn't be working at all. EI would certainly have a more consistent spark throughout the whole RPM range.
For the slow, smooth idle and easy starting I'd choose an EI any day over a mag but have several mag engines in my collection and they work just fine.
Old 04-03-2012, 07:25 PM
radfordc
My Feedback: (14)
radfordc's Avatar
On ebay... http://www.ebay.com/itm/5FT-Spark-Pl...item19ce9a10b1
5 feet of hi-tension spark plug wire. This is brand new 7mm copper-core wire
Old 04-04-2012, 06:23 AM
spaceworm
ORIGINAL: radfordc
OK, but that wire is 7mm. Back a few posts W8YE said our need is for 5mm wire.
Question: is Essex Magwire still around? But, that wire is likely 7 or 8 mm also.
Old 04-04-2012, 07:50 AM
Baldeagle
My Feedback: (7)
Check with Ralph Cunningham with RC ignition , He can fix you up either way you deside to go.
