G-45 Engine Bolt Size?
Old 04-09-2012, 05:46 PM
Tony Gag Jr.
My Feedback: (124)
Tony Gag Jr.'s Avatar
Default G-45 Engine Bolt Size?
I have a G-45 and I need to drill out some props. What is the correct size to open the hole on the prop?
Tony
Old 04-09-2012, 06:11 PM
All Day Dan
All Day Dan's Avatar
Default RE: G-45 Engine Bolt Size?
Tony, It's 10mm according to Horizon Hobby. What ever the size is, don't use a drill or a reamer. You need a counter bore with a pilot in a drill press to keep the hole centered. Dan.
Old 04-10-2012, 11:37 AM
Tony Gag Jr.
My Feedback: (124)
Thanks Dan! Any idea where I could buy that kind of drill bit?
Old 04-10-2012, 12:02 PM
All Day Dan
Tony, here is what I use. It's a .375 counterbore with a .25 pilot. There are hobby items around but they are not that good for this purpose. I got mine at a tool store that supplies machine shops. Try these guys if you can't find some thing like I have around where you live. Don't settle for something less. It is too important. Dan
http://www.mcmaster.com/#counterbores/=h1rc2d
Old 04-10-2012, 01:02 PM
Tony Gag Jr.
My Feedback: (124)
Thank you very much Dan! That is the size you use for the G-45? I assume a G-62 is the same size?
Thanks again!!!!
Tony
Old 04-10-2012, 01:21 PM
All Day Dan
Tony, I use the .375 counterbore for a Brison 3.2 engine which has a 3/8 inch crankshaft. The 1/4 inch pilot is for the hole in the Zinger 20 X 11 propeller that I use. Dan.
Old 04-10-2012, 05:49 PM
Tony Gag Jr.
My Feedback: (124)
Thanks again Dan. I will check out that link and see if they have what I need. Appreciate the help!!
Old 04-10-2012, 06:21 PM
All Day Dan
Tony, thanks for the thanks. Dan.
