3 or 4 blade prop size for DLE 55???? :-(
I just build a Great Planes Edge 540 27% with a DLE 540 gas engine. I am hearing that my idea of a 20x12 prop is to small? I think the ground clearance for the 22-23" is a bit close. I was wondering what size 3-blade or 4-blade prop I can use in substitution? Will this adversely affect my 3D flying? Where can I buy a 3-4 blade at? I checked online and can only fine 10" ones around? Thanks:-)
RE: 3 or 4 blade prop size for DLE 55???? :-(
There is a company in Taiwan that makes a scale Hamilton three blade prop setup that has adjustable pitch too.
A user on that other forum called UncleGeorge who sells them here in the USA.
it is a 20-10 through 12 pitch prop. it uses carbon fiber composite blades. The prop is intended for use on 50cc size engines.
My Feedback: (66)
As I stated in your other post you need a 20x12 3 Blade prop. You need to look harder on the internet. tons of props out there.
http://www.troybuiltmodels.com/items/BP2012-3BY.html
ORIGINAL: rcpilotjwg
