EME new engines, 35,60 & 120 twin
Old 11-13-2016, 01:46 PM
  #201
Arizona Flyer
My Feedback: (14)
CYMAZ,
I love my 120 and also bought the 60 for my Yak. I have been absolutely beating this plane (3D) for three years and the engine still runs strong. Had to replace the carb and intake once but that's it. Also for what it's worth, Mike from Mile High RC still carries them, he wouldn't be if there are issues I'm sure.
Old 11-13-2016, 02:09 PM
  #202
cymaz
cymaz's Avatar
Cheers for that, excellent engine then!
Old 11-22-2016, 07:21 PM
  #203
AeroGasRC
On the 60cc what is the HP and a question on the starter system,can the electric motor be mounted on either side or ??
Old 11-23-2016, 05:45 AM
  #204
BarracudaHockey
BarracudaHockey's Avatar
HP ratings on model engines are best guesses, I dont even bother with the published figures.
Old 12-16-2016, 11:40 PM
  #205
cymaz
cymaz's Avatar
Reading the manual for the 120cc, it's a bit short on detail about running in!
It says not to use synthetic oil. It gives no indication on what oil to use, %'s , and how long the running in should be. I have emailed the factory so hope to get a reply in the near future.
Meanwhile, would anyone like to share their running in tips and experiences??
Old 12-17-2016, 03:37 AM
  #206
BarracudaHockey
Yep, 40:1 RedLine
Runs like a top
Break in oil went out with the 8 track
Old 12-17-2016, 09:19 AM
  #207
cymaz
cymaz's Avatar
Originally Posted by BarracudaHockey
Yep, 40:1 RedLine
Runs like a top
"8 track " ??. Could you please explain...
Old 02-15-2017, 05:59 PM
  #208
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
I'm going crazy trying to make up my mind on a 35cc motor for a 1/4 scale Katana.
looking at the EME 35s specifications compared to the DLE 35s and the new RCGF 35ra, it would seem the EME is down on power, has anybody had experience with the EME 35 vs the DLE 35ra?
I have noticed that I've seen a lot of used DLE 35ra for sale, I have never seen a used EME 35 for sale, that alone says something.
Old 02-15-2017, 10:24 PM
  #209
cymaz
cymaz's Avatar
I suspect there isn't the volume of EME engines in the market compared to the DLE brand...
here is the utube of my 120 cc first run. Miss out the first 2 minutes, I left the ignition switch off
https://m.youtube.com/watch?v=BM7ZZ69e6wg
Old 02-16-2017, 05:34 AM
  #210
BarracudaHockey
Unless you setup a test where you're doing a static pull test with the same prop and fuel on the same day then you're not going to have a real comparison. Looking at manufacturer published HP figures is nothing more than marketing and guesswork for the most part.
Old 02-16-2017, 09:02 AM
  #211
Truckracer
My Feedback: (19)
A local friend has several DLE35 and one EME35. All run very well. From watching them perform, the DLE may have the power edge but I wouldn't have any problems owning either engine. The EME picked up quite a bit of power during the break in process .... a more noticeable increase than some other engines. The EME comes with a very small muffler which translates to loud but the DLE 35 muffler isn't noted for being overly quiet. The EME uses 5mm prop bolts compared to the more common 4mm used on the DLE and other engines in that size range.
For me (and I own a DLE35) buying another 35 would boil down to which engine fit the application the best. If the rear exhaust would work out the best, I'd buy the DLE. If a side exhaust would fit the best, the EME would be high on the list.
Old 03-01-2017, 06:11 AM
  #212
fast 1
who is selling this in the states and how much ?
Old 03-01-2017, 10:05 AM
  #213
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
http://www.milehighrc.com prices very according to engine size of course, they start at $269.00 for the EME 35cc
Old 03-01-2017, 04:12 PM
  #214
fast 1
looking at 60 with electric start
Old 04-26-2017, 11:37 AM
  #215
hyflyer9
I am using a Falcon 23x10 prop and have ran 2 full 24oz tanks oil mix is 30 to 1 regular gas in Canada threw my EME 60 bot only getting around 5800 rpm .
Daniel.
Old 04-26-2017, 11:58 AM
  #216
cymaz
cymaz's Avatar
Now using a 24x12. Great engine. Starts really easily. 6600 WOT and a cool 1850 idle. Love it
Old 04-26-2017, 09:52 PM
  #217
Werlebird
Default Rpm
Hey what's everyone getting for rpm on their eme 120? I was getting around 6450 on the ground with a falcon 28x9.5. What I really want is lots of prop rip, so I went down to a falcon 28x8w. But I get the exact same rpm.... is there a rev limiter I am unaware of ? I figured I would of got a little more going down in pitch. Both props are carbon.
Any suggestions ? Or recommendations ?
thanks
jason
Old 04-27-2017, 09:46 AM
  #218
BarracudaHockey
Thats not apples to apples, the W means wide blade, so there's more blade.
Old 04-28-2017, 12:04 PM
  #219
Werlebird
I know what the w means, it's not a whole lot more blade on the wide falcons. Plus that's 1.5 degrees less pitch. Exact same rpm doesn't really make any sense
Old 06-20-2017, 04:38 AM
  #220
n8622t
My Feedback: (8)
Originally Posted by rcbill
I'm in the building stage here in Wisconsin but am anxiously waiting for more info and a video on the 120. Thanks for all you've done so far Bill
my 60 looks good on the outside but it has never been what I call a premium engine that could be compared to a DA or a DLE for that matter
Old 06-21-2017, 03:33 AM
  #221
SWORDSN
My Feedback: (13)
Where does it come up short?
Old 06-21-2017, 07:20 AM
  #222
n8622t
My Feedback: (8)
It's hard to start unless I use an electric starter , but it does seem to run strong. I have a DA60 and no other 60 class engine that I've seen comes close to the power and ease of operation It has
Old 06-21-2017, 07:52 AM
  #223
BarracudaHockey
Might just need a crack more open on the low end needle
Old 09-05-2018, 04:01 AM
  #224
Lifer
Lifer's Avatar
Need help with an EME 60 carb issue. I have several decades of experience with glow but only 10 or so years with gas. My EME has a couple of hours on it and I use largish props. I noticed early on the high speed needle had little effect. I assumed it was the large props but the other day I started richening the high speed needle and there was no effect. I counted 10 turns out. So, I went the other way trying to get a sag from being too lean. I actually closed the high speed needle and there was no change. The low speed needle was open 3.5 turns and it runs this way but I am concerned.
Contacted Mile High and got a vague response that did not address my question. So, can anybody tell me how this is even possible? Mile High sells "genuine" Walbro carbs for the engine, but I was told it is already a genuine Walbro. Any enlightenment is welcome?
Old 09-05-2018, 04:09 AM
  #225
DaleD
3.5 turns on your low end needle could be too much, remember the low end affects the entire range of operation. This could the the reason why you high end needle has little to no effect.
Suggest you try starting over the tuning process, set high end to 2.5 and low to 2 turns out and tune from there. Remember to properly warm up the engine and make very slight adjustments at a time.
DaleD
