Tech-Aero IBEC
Reply
Old 05-04-2012, 09:17 PM
vidasj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tech-Aero IBEC
Anyone using this? Opinions please.
I have an Aero-Works Extra 300 and DLE-20 on the way, and plan to use this IBEC. I've used the Rcexel ignition kill before, but the ignition had it's own battery pack. This plane I'd like to run a single battery.
vidasj is offline
Old 05-04-2012, 09:24 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tech-Aero IBEC
thats a good one
MetallicaJunkie is offline
Old 05-05-2012, 01:51 AM
aussiesteve
aussiesteve's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is the Only IBEC device I use. I have tried a few other brands and the Tech Aero is the best IMHO. (Some of the others are downright terrible and shouldn't be allowed to be sold due to their overall crapp!ness)
aussiesteve is offline
Old 05-05-2012, 02:33 AM
maineflyer
maineflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1, used others but the Tech Aero is the only one now.
maineflyer is offline
Old 05-05-2012, 03:54 AM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so this one is no good? http://www.syssaaircraft.net/cart/pc...5&idcategory=2 just curious because i will go this route(IBEC) on my next gasser
Old 05-05-2012, 04:13 AM
azalner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are one and the same
azalner is offline
Old 05-05-2012, 05:12 AM
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not here to knock the Tech Aero. I'm using one as well. What I wanted to add though, is there are a lot of guys running the Rcexl with no trouble as well? With that one you just need to assure yourself the ignition module is getting the correct voltage. That can be done pretty easily, on the cheap, with a diode or 2. If budget is of any concern, that package would run less than half the price of the Tech Aero.....
ahicks is offline
Old 05-05-2012, 05:41 AM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They used to be 55.00 now they are 39.00 , but some places are still charging the 55.00. Just thought I'd throw that out there!
AJsToyz is offline
Old 05-05-2012, 08:30 PM
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: AJsToyz
It's called competitive pricing. You can always buy it directly from Ed for 39$. But to me, even at 55$ it was a bargain for what you get. And so convenient to use....For example, just today my idle was a bit too high when I changed props and didn't realize it until the flying started. Well, the remote kill feature saved my plane's landing gear and/or some damage on the landing
I am still using Ed's original protype he hand soldered in one of my set ups. Have never had a single issue with any of the 4 I own and use regularly.
MTK is offline
Old 05-05-2012, 09:37 PM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where is it 39 bucks? i dont feel like going on a hunt
Old 05-06-2012, 01:23 AM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Todd Syssa has them for 39.95 or direct fro Tech Aero
http://www.tech-aero.net/ultra-ibec
AJsToyz is offline
Old 05-06-2012, 05:22 AM
rexbirk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have three. They work great! Have had troubles with some other brands but not these.
rexbirk is offline
Old 05-06-2012, 10:18 AM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: AJsToyz
thanks i didnt realize they had lowered the price at syssa
Old 05-06-2012, 10:44 AM
closetguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
never tried using a IBEC due to the fact that it's just another electric part that could go bad and guessing if it is working rite,i realy don't know that much about them.what i have been using is one 2300 a123 with a diode from WrongWay rc
to run both the ignition and rx that has work real well for the price of 8.00 bucks.what is the advantage to use a IBEC?
closetguy is offline
Old 05-06-2012, 12:23 PM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: closetguy
it filter out RFI for those who are still running on 72mhz, and it enables you to kill the engine from the transmitter
Old 05-06-2012, 01:09 PM
vidasj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't feel comfortable flying a gas engine without a means to shut it down in case of an emergency. IBEC or kill switch, it's still "another device to go bad", but I think a necessary one.
I got the Tech-Aeo on order, glad to see so many positive responses. One less battery and switch on my next plane.
vidasj is offline
Old 05-06-2012, 02:18 PM
aussiesteve
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: closetguy
You are pretty much right in the fact that it is another electronic device to have problems with.
the ONLY places I use IBECS are in smaller planes (28cc gassers and smaller). In anything larger, I don't bother trying to save the very small weight of an additional ignition battery. (you can save more weight than that by reducing the "Bling" fitted for aesthetics).
In my IMAC planes, it is "almost" mandatory here to use RX operated ignition kills (It is not actually written but most organisers consider it to be the rules so it is easier to just go with the flow). As those planes are all larger than the ones I use IBECS on, They use a simple optikcal kill device connected to the seperate ignition battery/s (also of only one particular brand).
If the need for an Rx kill is considered necessary (that need may be for personal peace of mind) then one should also be using 2 RX power packs. etc.
But then again, I consider planes much smaller than that to be glow territory anyway as I never had a problem running that technology - no need for any of the baove on those
(Wait for it - I am sure it wil come [8D])
Old 05-07-2012, 05:36 AM
gringopete
gringopete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its other real advantage is that if you lose radio signal the engine shuts down, preventing a fly away or something worse. We have sold hundredsof them and have had no problems.
Ed Alt is real serious about these. He did not produce them untill ALLof the bugs were out.
By the way they are assembled here in the USA.
gringopete is offline
Reply
Display Modes
