Bolt mounting pattern for Q35 vs Q42
MN
Is the mounting pattern for the Quadra 35 different from the Quadra 42? It looke like the Quadra 35 has the two holes closer to the cylinder are closer together than the ones on the bottom of the engine. But the Quadra 42 looks like it has the same spacing top and bottom. Is this correct, or am I looking at a US 41 instead of a Quadra 42?
