If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    Join Date
    Jun 2012
    Palm Coast, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    US 41 engine manual
    I am trying to locate a pdf of the manual for the US41 gas engine, I have searched a couple of time with no success, does anyone have a copy of the manual in pdf or know of a link??
    Thanks in advance
  2. #2
    Join Date
    Feb 2002
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: US 41 engine manual
    I think I still have a copy of my Quadra manual somewhere in my files. I have both engines and the Quadra manual is good for both. Send me a PM and I will send it back. Meanwhile, I see if I can find it.
    Bedford
  3. #3
    Join Date
    Nov 2002
    westbrook, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    theres one in the quadra aerow engine forum. if you read the pdf they say run 20:1 gas to oil ?
  4. #4
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  5. #5
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: WhiteRook
    My guess is that's due to the oil commonly available at the time? Today's oils allow 40 and 50:1 to be much more common.
  6. #6
    Join Date
    Nov 2002
    westbrook, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    probly true . the oils might be better now. I just bought a Q100B used and , do you know what size the threaded holes
    are on the mount ? there are 2 non threaded that are mabey 5mm and 2 threaded .
  7. #7
    Join Date
    Dec 2006
    Converse, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can anyone tell me what kit number for the walbro carb. is? I have an older engine (US41) that is new, but would like to replace the kit with one that is compatable with gas mixed with ethanol. Read on an older post that the carb. number should be near the fuel nipple, but did not see one. Thank's in advance for any help!
  8. #8
    Join Date
    Jun 2012
    Palm Coast, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the qutra manual, I forgot the mixture and thought I was using 40:1 but the manual saying 20:1 for regular 30wt oil, I guess 40:1 should be OK if I run amsoil??
  9. #9
    Join Date
    Feb 2002
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    94,
    You open a mammouth subject asking about oil. Stand by. I ran mine on off-the-shelf air cooled engine oil (WalMart or elsewhere) at about 32:1. After a while I converted to Amsoil synthetic at 100:1. There has been MANY negative things said about this Amsoil on these pages, but it has worked for me. DO NOT take the Amsoil intended for 100:1 and think you can get away with working it at 50:1. That is not a viable solution. I think Amsoil says you should not go stronger than about 80:1. They have other mixes for stronger ratios.
    This engine will respond to most any oil ratio you give it so long as you follow the oil manufacturer's directions, and avoid water-cooled outboard motor oil.
    That is just me.
    Bedford
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
