g-62 prop
My Feedback: (126)
NY
g-62 prop
I put a g-62 with a xoar 23 x 8 prop on my 1/3 pup , Im getting 6200 at wot, is this good enough for this combo or some thing differant prop that is ?
thanks charlie
thanks charlie
RE: g-62 prop
With the information given, it seems about right.
Propeller type and muffler however can have a huge impact on engine rpm. The Xoar loads an engine a bit more than other props. You get about 4.2hp, which would be typical for a good pitts muffler, and better than the standard Zenoah side muffler.
NC
RE: g-62 prop
ORIGINAL: lazyace
thanks charlie
thanks charlie
BC, CANADA
RE: g-62 prop
Around these parts we use a Zinger 24x8 on a 1/3 pup with G 62. Plenty of power, most of the time only using part throttle.
Zingers work fine, a pup is not a high performance aircraft...cheap too if you have a nose over and break it.[]
My Feedback: (19)
RE: g-62 prop
ORIGINAL: lazyace
thanks charlie
thanks charlie
Your 23-8 will probably work just fine but 6200 is kind of low for the G-62. You might also want to try something like a 24-6 or even a 23-6 if you can find one. The Pup will tell you if it is happy by the way it performs. The G-62 will also be happy even if it is out of its maximum performance RPM range if well cooled and lubed.
RE: g-62 prop
What the 62 likes is very depending on the muffler construction. I have data on both original side dump muffler and pitts mufflers.
The original muffler lets the engine peak at 9000 rpm with a very wide power curve top. The pitts has it's best power at 6500 rpm with a quite flat curve top, so 6200 rpm static is not bad at all, especially for a cub.
The Milton muffler is more powerful, and it seems to do it's job at lower rpm.
VA
RE: g-62 prop
Mejzlik 22x10 it will spin up to 7100 rpm's The engine can happily spin this all day. Prop pulls great This is the benchmark prop for the g62. You will love the performance
My Feedback: (19)
RE: g-62 prop
ORIGINAL: harley6133
RE: g-62 prop
Precently I´m using a Fiala 26x8 on my G-62 equipped 1:3 scale Tri-Pacer. The tips have been rounded to make it look more scale, and the engine spins it at around 6300 (6100 before rounding the tips). Plenty of power for a 37lb big fat pig. :-)
P.S. I´m using the stock twin outlet silencer, with a 2-into-1 collectorpipe. Very noisy unfortunately, but the fact that I hardly ever gets over 1/2 throttle helps a lot.
RE: g-62 prop
ORIGINAL: pe reivers
you must be talking of the 80cc boxer engine, not the 62cc single?
But it seems to me that the Fiala type propeller loads quite a bit less than the same size Menz for example. I used to fly with a Menz 26x8, and it would do around 5300 rpm. That was on a different silencer though (Toni Clark piper style).
The bigger diameter propeller helps lower the idle, as I get a reliable idle of around 1000-1100rpm on the Tri-Pacer.
