New DLE 35
Reply
Old 08-28-2012, 08:19 AM
  #101
rmoose
rmoose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New DLE 35
as far as tuning get engine running let run about 10 mins then open throttle wide open and ajust high end first to max rpms like a glow engine. once you start leaning out engine it will start slowing down, then backup screw it max rpms are back then richen it abot to a 200 rpm drop rich side your done with that. then idle down to about 1700 and wait 5 sec, gag throttle open if engine stalls or hesitates its to lean on the low endONLY turn screw openthesame with of the screwdrive slot at a time. folks have ahabit of turning screws to much they are very senstive....repeat till engine has no hesitation or stumble form idle to wide open no matter how fast tyou gag it and your set , under any reason NEVER I REPEAT NEVER force screws tight all the way closed if your wainting to reset to factory setting. if you do go ahead and order your self another carb cause you just runnied that one ... good luck and happy flying
rmoose is offline
Old 09-02-2012, 07:04 AM
  #102
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why do you want to back it off to lose 2-300rpm? Its not a glow engine! Set the high speed needle for maximum rpm and leave it there!!!
TimBle is offline
Old 09-02-2012, 07:21 AM
  #103
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TimBle
I do that for a few reasons. The first is because the engine is going to unload in the air. Next is because I would much rather have the engine on the rich side for reliability purposes, knowing the likelihood/potential for a lean engine to quit is greater when compared to a rich one. Last, this is a ground adjustment I KNOW I'm very likely going to have to change. I'd much rather sneak up on optimum tune from the rich side....
That's me though, FWIW. -Al
ahicks is offline
Old 09-02-2012, 09:15 AM
  #104
willoukw
willoukw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
one needs to richen high side ajustmentabout 200 rpm to 300rpm because engine will still lean out when unwinding during flight if to lean engine will get hot andpossibly sieze. and you sure dont what the cly. and the piston becoming one. wont make for a good day. and a very costly one as well. a gas engine slinging a 19x8 proparound 8000 if it suddenly stops . besides running the engine the prop bolts like on a dle will proubly shear off and chunck the prop and spinner. possibly even break the crank. bend the rod ect. list of damage can go on and on
willoukw is offline
Old 09-02-2012, 10:39 AM
  #105
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plus 1 for a bit on the rich side (unless you're in a race!).
Lifer is offline
Old 09-02-2012, 11:08 AM
  #106
rc34074
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rcguy59
That's why I like the Sierra gear. When I first put this bird together, I used a set of SpringAir gear that I had on hand. They weren't up to it.
rcguy - which SpringAir gear part number did you use in this plane? What were the specific problems you saw with them?
thanks
Ed
rc34074 is offline
Old 09-02-2012, 11:37 AM
  #107
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know the part # of these retracts. They're probably 20 years old. The main problem lies in the length of the leg. It bent very easily and would wedge the tire in the well, refusing to come back down when needed. I got WAY too much belly-landing practice. The retracts themselves were adequate, (barely) but the internal spring was a bit weak. The Sierras have been flawless and really let me enjoy flying this brick without worrying about the gear.
rcguy59 is offline
Old 09-02-2012, 02:37 PM
  #108
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry chaps but the leaning out of a pumped petrol engine carburettor "once it unloads" is hogwash. This is glow engine thinking and it does NOT apply to a petrol engine.
Rich running engines are not more reliable than a slighly lean engine. It may run a few degrees cooler. If there petrol, air and spark it will fire....simple as that.
Lastly how in heck is gaining altitude in flight it going to change the mixture significantly? Air is a lot less dense than water so it does not change barometric pressure significantly every 10m  altitude gained.
tuning these things is so simple. allow for 30sec to warm up and open up to WOT and set the high speed needle for peak rpm.
Then ease back on the throttle till its starts to pop and miss (4 stroke) and lean the LOW sped needle till it goes away, then ease back on the throotle again till the next 4 stroking point is reached and lean the LSN again till it stops. repeat till you get to idle. Check for transition through the rev range and anywhere it feels lean, richen back up a little, or if it still 4stroke, lean further. Work you way back up to WOT and then again ease back on the thottle. If no 4 stroking occurs then its good to go but its likely it will still have a spot somewhere in the rev range where it will briefly 4 stroke.
forget your glow engine thinking with petrol engines.
TimBle is offline
Old 09-02-2012, 03:24 PM
  #109
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TimBle
Sorry TimBle. Though we agree on many points, these may become sticking points. In my experience a lean engine is far more likely to quit compared to a rich one - even though it is being fed a steady diet of petrol, air and spark. Though given that's true in the most basic sense, these commodities must be delivered in the proper proportion for an engine to continue running.
ahicks is offline
Old 09-02-2012, 03:27 PM
  #110
rmoose
rmoose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sounds good chap but your forgeting many things? what ever happen to wind drag and the load on the engine. due to the weight of the aircraft plus the speed of the aircraft. and who said anything abour baro. pressure?so your saying that a engine turns the same rpms on the ground as it does in a 100 mph. in adive WRONG ! you.run your engines lean and see what happens when they suddenly lock up.
rmoose is offline
Old 09-02-2012, 03:28 PM
  #111
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will add my two cent's here. Past experience with engine's, at the very least, running lean can burn a hole in the piston from excessive heat at detination.
acerc is offline
Old 09-02-2012, 03:38 PM
  #112
airraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acerc
then that is to lean then.
tune it like Tim said. i have never ran these rich on the ground so they are just right because they unload in the air. that is just silly. its a pumped engine. on you glow engine with a pump did you max it out then richen it so it could be just right when it unloads. lol no you didnt. so why would do the same here.
Most guys have to have their engines on the rich side because they dont know how to cool these engines correctly so they have to run the on the rich side to help with cooling.
airraptor is offline
Old 09-02-2012, 04:41 PM
  #113
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: airraptor
Use the reason you prefer to do so, but it's not going to change my belief a rich engine is far more likely to be running when it lands than a lean one? My understanding is we're talking about the first flight after ground tuning right? Launching a couple hundred rpm. rich of max rpm?? Not the final adjustment that's resulted from many flights, and potentially a few "tweaks" of the adjustment screw?
ahicks is offline
Old 09-02-2012, 04:52 PM
  #114
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TimBle
Here is yet another way to tune a engine after break-in.
Warm the engine up a bit and adjust the HI-speed untill you get max RPM and then richen it to just starting to drop RPM(about 50 RPM or so). Set the idle mix so the engine does not stumble on a quick opening of the throttle. Fly your airplane a bit and if it sounds good make a couple of hi-speed passes and kill the engine in flight and glide it too a landing. Most airplanes will land easy with engine dead if you set up your landing approach right.
The idea is to stop the engine in flight and land for that important sparkplug check too see if the Hi-speed mix is set correct. The sparkplug should be a tan color. If white or the mix is too lean. If real dark ...the mix is too rich. Give it a try...you got too know if you can land that bird on a dead stick anyway.
captinjohn is offline
Old 09-02-2012, 04:57 PM
  #115
rmoose
rmoose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
anyway you all tune your engine as you please we can disgree all night 200 rpm richis the setting on the high side. but we seem to have a big know it all war here .that rich mixtureis the way my engines runperfect.and i work on alot of engines for other folks i just finished a set ofdle-55 to go on a yellow aircraftp-38 lighting one runing clockwise and one running counter clockwise. with 3 bladed props one pusher and one pulling anyway good luck i have nothing else to say about tuneing carbs i know what im doing! this room is about the new dle-35 not a he said she said 200rpm hackering chat
rmoose is offline
Old 09-03-2012, 03:37 AM
  #116
SigMan
SigMan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Free Rcexl Opto gas kill switch, CM6 spark plug and Black switch with charge jack and fuel dot included with engine purchase! makes it a pretty god deal. should be a Monster.
SigMan is offline
Old 09-03-2012, 07:42 AM
  #117
airraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SigMan
where??
Old 09-03-2012, 07:48 AM
  #118
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
  http://www.valleyviewrc.com/estore/
acerc is offline
Old 09-03-2012, 08:21 AM
  #119
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone still not believing the price of this engine isn't going to drop once the pipeline fills up?
ahicks is offline
Old 09-03-2012, 09:02 AM
  #120
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Supply and demand. No more demand no more overpriced.
acerc is offline
Old 09-03-2012, 11:41 AM
  #121
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 30 is staying so its unlikely the price on the 35 will drop. Its not replacing the 30...
TimBle is offline
Old 09-03-2012, 12:07 PM
  #122
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ValleyViewRC Is selling 35's as fast as they can get them. While I agree that the engine is a bit pricey, don't hold your breath waiting for it to come down.
rcguy59 is offline
Old 09-03-2012, 01:07 PM
  #123
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some photos a friend took of my Bearcat in action.
ID:	1798035   Click image for larger version
ID:	1798036   Click image for larger version
ID:	1798037   Click image for larger version
rcguy59 is offline
  #124
SigMan
SigMan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SigMan is offline
Old 09-19-2012, 08:44 PM
  #125
Condor060
Condor060's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey ya fellas, I caught your thread on the DLE 35 and wanted to show you the newest project Troy Built has me working on. I have one of their 71 inch Mustangs with the DLE 35. We flite metaled the stang, installed a Keleo custom exhaust and are using a 17 inch 4 bladder. We also installed a Dynamic Balsa Cockpit kit. Thought I might share a few pics and some results once we get her breathing some fire.
ID:	1803075   Click image for larger version
ID:	1803076   Click image for larger version
ID:	1803077   Click image for larger version
ID:	1803078   Click image for larger version
ID:	1803079   Click image for larger version
Condor060 is offline
Reply
Display Modes
