Why don't we have more 4 stroke gassers?
#52
RE: Why don't we have more 4 stroke gassers?
ORIGINAL: captinjohn
That china made 4 cycle gas engine looks like a ENLARGED Magnum 4 stroke engine.....kinda ! I agree it will take quite some time for china to make a good reliable 4 stroke GAS engine. I bet the first production run engines will need to be improved....just like the other china made 2 cycle gas engines...........
I hope the customers won't be QC guinea pigs.
#53
ORIGINAL: Whistling Death
That looks like a dead nuts upscale copy of the Magnum.
#54
they think a youtube video is enough to convice people to buy their crap engines.
I will consider this 4 stroke engine if they send FREE samples to aussiesteve or reputable pilots in the USA.
he won't even improve this engine because he has other 4 stroke engines on the way, for him the most important is $$
#55
ORIGINAL: Mikola
IMO they don't have a team pilot they just make a test on the bench before shipping to their distributors.
#56
Wondering why the piston was made with three ring grooves? I know the Saito glow four stroke only uses one ring, not sure about the gas, or the other companies. The NGH has two compression rings and an oil ring groove? Was this piston made for this engine or was the displacement made around the piston?
Andy
Andy
#58
ORIGINAL: Mikola
Michael has several professionals to test worldwide.Also they have some friends to fly for them nearby.
#59
Turk,
It seems the majority of the problem engines come from China, I don't think that was directed at Michael. It just seems about 50% of the engines and engine designs coming out of China fail and go to the way side and the consumer is left holding the bag.
I hope these work out, I just won't be one of the ones rolling the dice to find out.
Andy
Andy
#60
ORIGINAL: Turk1
let me know the name of those professional pilots and what kind of test are they doing.....
if he has several professional pilots around the world, why does he always post on american forums youtube videos of his guinea pigs ?
#61
ORIGINAL: Mikola
several professionals ? they get paid for testing chinese engines ? wow!
if he has several professional pilots around the world, why does he always post on american forums youtube videos of his guinea pigs ? [img][/img]
ORIGINAL: Turk1
ORIGINAL: Mikola
Those you see at youtube are from us using these engines.
Did you use any of his engines?
I am.And I m happy with them and especially with support.I am a guinea pig of him.
#62
ORIGINAL: AJsToyz
Turk,
Andy
Turk,
Andy
I am using JBA and SK Glow engines maybe since their first days and very happy with them on quality and price aspect.Also I am experiencing on NGH gassers here on friend s planes.Also they are fine engines.Michael is always backing of his products.
#63
ORIGINAL: AJsToyz
Andy
Andy
#64
[quote]ORIGINAL: AJsToyz
....... I just won't be one of the ones rolling the dice to find out.
#65
ORIGINAL: MTK
I'd hazard a guess...weight savings?? (TIC)
ORIGINAL: AJsToyz
Andy
Andy
I bet if one Frank Bowman ring was used....one ring would be fine. If 2cycle oil is mixed in the gas for lubrication...you want oil to by-pass the piston and lube the bottom end. With 3 rings oil may not collect where it should. Just a wild Idea !
#66
From Micheal Chow
" The first ring is pressure ring, second ring is oil ring, they are with different shapes and functions. third groove idea is from glow engine piston store some oil and dirt while engine running.
made a solution for supercharging and lubricating, there are two nipples on INTAKE MANIFOLD, and two nipples on Back cover. need be connected with pipeline.
Two nipples on Intake-Manifold: one is no pass to intake-manifold but pass to Walbro carb, one connection from back cover, so the pressure from crankcase to carb via this nipple to supercharge.
one nipple is pass to intake-manifold and connected from another nipple on back cover.
So, when piston move from TDC to BDC, the pressure from crankcase boost to carb and manifold via two connections.
when piston move from BDC to TDC, the negative pressure from crankcase will suck gas mixture to crankcase via the another nipple connection (not from carb connection nipple, one-way), to lubricate the roller bearing, and there is a hole inside the crankshaft, the oil transferred into cam gear for lubrication via this hole.
when engine running, the carb will pump twice for each cycle, one is effective pump, one is noneffective, and now make second noneffective pump to send oil to crankcase for lubrication via the seond nipple on manifold to second nipple on back cover.
I am sorry it is hard to explain with my poor English. "
#67
CA
cost.......
Here is a stihl 65cc 4-stroke I converted. The power is about the same as a G62. The airplane is a Bridi big bee. The prop is a Vess 23A. The oil is in the gas. Sounds like a flying lawnmower.
http://scotplanes.shutterfly.com/pictures
#68
That video on page 1 of this thread about the Galloping Ghost P51 Mustang rc, what engine does it have ???
Youtube id is 5PnJkBl0Ql8.
I love the sound and it packs quite a lot of punch too.
#69
ORIGINAL: JariV
They should be going into production anytime now, as they have been flight testing the engines for quite a while now.
#71
Why don't we have any RC Airplane Hit and Miss engines?
We do just call Hobby King, sometimes they Hit and sometimes they miss!
#72
My Feedback: (34)
LOL not funny
It was a real question, as Im in the market for a 30-40cc size 4 stroke. As there are a larg number of war birds out there that use 30cc, that Im sure would love the sound if nothing eles.
I was not around when 2 stroke nitro motors first came out, but Im sure it took a while before the first 4 stroke hit the market.And it seems to me that 2 stroke gas motors are here to stay so how much longer do you think it will take before the market chaces up?
#73
No oil pan or oil reserve for lub. Think YS where the fuel and oil are drawn in the crankcase and compressed up into the intake chamber. http://www.shindaiwa-tools.co.uk/index.php?id=141
Dennis
Dennis
