Old C&H ignition expertly repaired!
Reply
Old 07-19-2012, 03:16 PM
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Old C&H ignition expertly repaired!
Good choice keeping the CH's !!!
John
gr8flyer55 is offline
Old 07-24-2012, 04:31 PM
WhiteRook
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is the 100B CH setup
ID:	1785620   Click image for larger version
WhiteRook is offline
Old 07-26-2012, 06:30 AM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: WhiteRook
I had a 4.2 cubic inch chainsaw engine that looked simular too that 100. It sure must have some power ! Capt,n
captinjohn is offline
Old 07-26-2012, 01:02 PM
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Captin'.
Your test ignition for your planes went out this afternoon. Please overlook the aluminum box it's in and concentrate your review on the performance of the goodies inside.
John
Old 07-26-2012, 04:09 PM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
gr8flyer-john, I got to get a 35ccWebraBully running(new) and I can test your ignition and then my RCXEL ignition and see what does what. That will be a week -10 days away. To much going on here right now.Best Regards,Capt,n
Old 07-30-2012, 09:19 PM
  #31
Bass1
Bass1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John, I'm having a sensor issue.. Sent you a PM
Bass1 is offline
Old 07-31-2012, 04:15 AM
  #32
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ben, give me the diameter and length of the sensor being held in the Delrin ring and I'll make you one. Easy to do.
John
Old 07-31-2012, 08:04 AM
  #33
Bass1
Bass1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John, The sensor diameter is 5/16th of an inch and sensor length is exactly 1 inch long. The entire length of the pigtail assembly from tip of sensor to the end of the pins at the connecter is 13 inches long. Sorry about the blurry photo but I was only on my first cup of coffee
Bass1 is offline
Old 07-31-2012, 08:54 AM
  #34
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It'll be in the mail tomorrow.
John
Old 07-31-2012, 09:28 AM
  #35
Bass1
Bass1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fantastic! Let me know the price and I'll send it off tomorrow as well. Thanks, You're a life (plane) saver!
Bass1 is offline
Old 08-06-2012, 08:39 PM
  #36
Bass1
Bass1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John, I got the sensor in the mail on Saturday and it looks great. I haven't had a chance to install it yet as I've been up to my elbows in rebuilding a basket case trainer for a friend. Just about finished with it now and will try to install it and fire up the engine either Tuesday or Wednesday if the relentless frog stranglin' thunderstorms ease up a bit. THANKS for getting it to me in a most expeditious manner! I'll let you know how she runs...
Bass1 is offline
Old 08-06-2012, 10:07 PM
  #37
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ben, it might be a few thousandths smaller in diameter than 5/16". This is the carbon fiber tube I use for most of that type application. Smear a little silicone sealer on it and see if it holds it. Most I make are just a tad loose so you can use the silicone to hold em in case they ever need replacing. Hope this gets you back in the air quickly.
John
Old 08-09-2012, 04:58 PM
  #38
Bass1
Bass1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John, The sensor fits and works perfectly. It slid right into the hole in the Delrin timing ring and just tightening the set screw secured it firmly. No silicone needed!
Bass1 is offline
Old 08-09-2012, 05:19 PM
  #39
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great Ben...
I'm glad it fits the ring. Hope this solves your sensor issues now. Let me know when you get time to run the engine with everything finally replaced and working.
I may have some more units by end of august and a few spares built as well for future use. Started folding up some smaller aluminum boxes for the new setup with multi spark. As always, I'm flying one in my plane doing testing. So far it's been great with battery life. Getting over 2 hours on an 800 mah NiMH pack, which is a good bit of run time for my flying style.
John
Old 08-13-2012, 04:23 PM
  #40
closetguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John,got the ignition that you made for me today.i was sort of surprise that it look just like a rcxel ignition,thats a good thing because it fits the same spot as the old one did.i was expecting it to look the old CH ignition with the aluminum box.
its on the plane now and getting a nice loud sharp snap and good blue spark.i will fly it tomorrow and let you now how it goes.you will be getting more business from me for sure.
closetguy is offline
Old 08-13-2012, 06:11 PM
  #41
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad you liked the ignition. Actually I make them both ways. Aluminum box or like yours. Same thing inside both boxes.
Performance should be equal to or better than the old ignition which was made by RCxel. Let us know how it works out.
John
Old 08-14-2012, 04:51 AM
  #42
closetguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it's raining out, thought i try this for first time.thought some might want to see the ignition that John made me. it's on a 50cc WrongWay profile..[img][/img]
Old 08-16-2012, 11:39 AM
  #43
FlipSideFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: gr8flyer55
Thanks for the kind words Bass1 !
Working on the older CH ignitions is something I seem to do more of these days. While they were extremely reliable and well thought out designs, even the most robust designs can be rendered useless in a bad crash. Took a little probing and some freeze mist but found the problems and yours was up and running in no time. We all owe a debt of gratitude to Bill Carpenter for his life long work supplying us in this hobby with the marvels of CDI ignitions.
I for one, love the design. Easily repaired if you doink it in a crash. I can't improve on perfection, just offer new life for otherwise inoperable ignitions. CH designs were mirror image copied by RCexl a few years back, but there is nothing like a CH !!
By the way Bass1, goodies inside your returning box this week, couldn't help myself. Lol
Trial units for your next project!
John
I too agree...nothing quite like a CH.
Just a heads up on the differences that I’ve experienced between the CH (2006 vintage?, single edition) and the RCxel (2012, ver 2) installed on a Zenoah G-62.
Both the CH ignition and the RCxel ignition systems were tested on the same engine and in the same airplane without any changes being made to power system (e.g., same 4.8 v NiMh battery, JR mechanical switch, RCxel electronic switch, connecting leads, etc.).
Both resulted in easy starts and produced nearly identical top end performance 6,400 – 6,700 RPM. Likewise, both produced nearly identical idle performance – with the CH system being the slight winner when it could idle the engine down to less than 800 RPM!!! Yea, that's slower than I set it!!
However, the BIG difference that I’ve noticed, between the two systems, occurs during flight. Whenever transitioning from high or mid-range power to idle, the CH system is totally rock-solid and extremely linear throughout.
The RCxel system, on the other hand, hunts badly as it approaches idle speed and continues hunting throughout the entire time it takes the plane to slow to near stall speed. Once back on the runway, it idles steady. Not a biggie, but it is a tad disconcerting while trying to fly slow-speed maneuvers.
I’ve tried various gap settings on the RCxel pickup sensor and also tried altering the fuel mixture settings; however, the in-flight “hunting” still persists. I’m thinking that the RCxel mapping just doesn’t handle no-load conditions like the old CH can. That's just a guess on my part as I have since installed the RCxel on another plane also G-62 equipped, with the same results.
Update: Problem Fixed??? Flew the RCxel-equipped airplane a half dozen times this past week and NO problems with hunting! Tried three different props; PK 22 X 6-10; Top Flite 22 X 6-10 and a Zinger 22 X 10 all with the same result…in the air or on the ground the engine slows to idle without any hunting. Sorry folks, although I’m pleased the problem is gone, I’m at a lost as to say why.
FlipSideFlyer is offline
Old 08-19-2012, 11:11 AM
  #44
closetguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
got a few flights on the new ignition this weekend,can't complain about anything at all.starts easy,idles great(i think smoother than the rcexl),couldn't tell any difference in top RPM's,transtions from idle to WOT seems better also.
i am getting a better, wider spark,more blue and a louder snap.
GOOD JOB JOHN,your my new igniton supplier.
Old 08-19-2012, 12:54 PM
  #45
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for letting us know how it worked out. I'm glad you are pleased with my work. Makes me smile all day long!
More things being worked on for the future. Stay tuned!
John
Old 09-30-2012, 04:03 PM
  #46
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
flyer55, I made a couple of videos of the "Black Box ignition powering a Asscociated Statioary engine. It worked real good with instant starts. For some reason the video will not upload to YouTube from Picasa like it did before. I will figure it out ASAP though. Capt,n
Old 10-13-2012, 01:04 PM
  #47
WhiteRook
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I OWN a quadra 75 thats got a female deans plug end on the wire comming from the magnet. on my other setup on my Q100 ITS A 3 prong end . can i get an adapter that has two pronged ends ? so i can run a CH IGNITION with it .
Old 10-17-2012, 05:23 PM
  #48
gr8flyer55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pm me with your address and ill send one to you. Just tell me how long of a wire length between the plugs you need.
John
Old 11-16-2012, 10:36 AM
  #49
closetguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just have to give credit where it is due.John(AKA gr8flyer55) just sent a new Black Box ignition back to me. i fried the original one, i left the power on all night and after that i couldn't get any spark out of it.
sent it back to John and he sent me a brand new one,all i had to do is pay for the shipping there and back.
from now on he has all of my ignition needs,rcexl ignitions are a thing of the past for me.
THANKS, John
Old 11-17-2012, 03:56 AM
  #50
tande
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANKS, John
+1 ! ....
tande is offline
Reply
Display Modes
