Prop position on g62 video.
http://youtu.be/fWPwXKjeXpw
Found this g62 in my dads basement. Prob been sitting 10/20 years. It had a bennet mount on the back. I took that off and fabbed up that aluminum mount. Went to local scap yard, they ended up just giving me a nice chunk of t6 aluminum. While doing research about motor I learned that the prop should be mounted like shown in video? Not sure if I have it in the correct spot? I set both needles at 2 turns. Gonna spin a 22x10 zoar. Couple buds should be over in a few to help me get it started. Wish us luck. 91 inch tbm zero.
thanks
thanks
RE: Prop position on g62 video.
Best of luck with getting it up and running, just be prepared to do a carb rebuild, as after sitting idle for so long the diaphrams might be shot and in need of being replaced.
Karol
Karol
http://youtu.be/Zj-bm1w5nlY
Choked it for 5 flips,turned choke off. Started in 3 flips. Seems to run awsome. I'm really geeked.
Cheers.
My buddys never showed.
Cheers.
