electronic throttle
My Feedback: (34)
RE: electronic throttle
Sounds like a very challanging project. Perhaps it will someday be the standard control mechanism for throttles.. Good luck.
My real interest to let you know it was a Navy modified F-8 Crusader which actually made the first test flights.
We all call it fly by wire but technically it is " digital fly by wire" (DFBW). And is the standard today for many aircraft.
See post. http://www.nasa.gov/centers/dryden/n...-024-DFRC.html
However, a320 was the first airliner with DFBW.
My dodge ram Throttle body is Drive by wire. It has a small gear box on the drives side that opens and closes the throttle body blade based off what signal the computer sends from the drivers pedal. I think it would work but probably to pricey to even consider if they did come up with it. This is just my input.
ORIGINAL: rgburrill
Even in full size cars the electronic systems (throttle, fuel injection and ignition) are usually mounted on the firewall, not the engine. Fuel injectors can be considered servos. And the throttle control is either a servo or an air controlled device that is effectivly a servo. And yes, vibration is still a big issue as is temperature.
As Einstein said many, many years ago - if it ain't broke, don't fix it. Well that's not precisely what he said but it sums it up.
Pete
#31
My Feedback: (19)
I would not be in favor or any kind of throttle by wire control. What we have right now with conventional servo control offers excellent reliability, actuation speed, latency and resolution. This would be hard to duplicate (at a reasonable cost) using throttle by wire if an additional layer of processing was required. Now if we just mated a servo with the carb, that would be a different situation but would really accomplish little over our current remote servo installations. Reliability would probably decrease in the process. I'd like to watch a good 3D pilot flying with a throttle link that has poor resolution and high latency!
Now regarding the current generation of throttle by wire used in automotive applications ... Every one I have encountered has horrible resolution, considerable processing lag and the actuators are very s-l-o-w. OLD TECHNOLOGY throttle cables and direct linkages worked much better where throttle feel was important. Of course the new technology integrates much better with cruise control and other throttle related functions ..... but driver feel is gone in the process.
#33
I agree, the idea of having a servo integrated into our gas carbs sound like more trouble than it's worth.
As far as throttle by wire in cars goes, it's here to stay I think. Are any cars even being made today with mechanical throttle linkage?
Pete
Pete
#34
My Feedback: (19)
ORIGINAL: pilotpete2
Pete
Pete
#35
ORIGINAL: airraptor
A regular non digital servo from hitec is 20 dollars or less and a digital is 30 dollars so you will have to be cheaper than this to sell it.
#36
Isn't our R/C systems already fly by wire? I push the stick, the radio (Computer) generates output based on predetermined settings, transmits information to receiver, servo moves surface?
#37
AZ
ORIGINAL: Tony Hallo
