Prop mounting holes
Prop mounting holes
Here's a question for Gas engine manufacturers- Since the day has more or less come that manufacturers should standardize (e.g. cell phone chargers) their connections, why can't that be brought forward to the model engine suppliers? No not chargers for the engines but rather the propeller mounting holes for gas engines of approximately the same size? I would think that it should be possible to standardize the bolt pattern so that one could easily switch a prop from say a ZDZ - 3W or DA and others without having to redrill the prop creating more holes, possible balance problems, and possible weakness in the hub? Buying another CFK prop just to try it out on another plane with a different motor starts running into a lot of $$$$. For that matter, what drives the decision for each manufacturer to have a different pattern? Maybe we should all revert to ZG which only has a center bolt and nut? OK, Zenoah doesn't have the power engines as other manufacturers so that limits them to under 100cc. Let's face it- at over 120$ for a quality 3 blade CFK prop you don't want to have to keep buying props just to see what the performance difference is or what difference is makes for a decibel reading!
Would be interested in hearing what other people think about this.
RE: Prop mounting holes
[8D] While such universal mounting would be great for us customers , I highly doubt any manufacturer would willingly conform . From the manufacturer's point of view , why should we make it easy for you to use some other manufacturer's engine ? Once you've got your prop drilled to our engine , that's it , we got ya , either keep using our engine if ya like that particular prop , or get another prop for the different engine you want to try . The manufacturers aren't worried about making it easy for us customers to use other companies engines any more than the automobile manufacturers care to make us able to use any other auto maker's wheels or engines on their cars .
Just so ya know , I DO agree that it would be great to have a single specification prop hub for the different size class engines , But I highly doubt the manufacturers would comply willingly for the reason stated above .
+1,
I don't know the upper displacement limit for a single bolt prop setup as far as displacement goes, but I do know, I'll never own an engine in the displacement range that would actually require a 4 bolt setup.
Pete
Pete
NC
ORIGINAL: pilotpete2
+1,
Pete
+1,
Pete
My Feedback: (13)
OR
ORIGINAL: STUKA BARRY
I dont understand your logic on this statement as a DLE 30cc which is a very small gas engine has a multi bolt hub.
+1,
Pete
+1,
Pete
ORIGINAL: rangerfredbob
He means that 99% of all engines with a multi bolt prop hub don't ''need'' them, I don't remember what TOM or Antique said was the upper limit of a single 3/8'' prop bolt but I think it was in the 250cc range, which is well beyond what 99% of us will ever fly...
The OS33 and SAP180 come with prop shafts/nuts, standard. There is no issue with either engine keeping props on. I also wish that multi bolt prop hubs become a thing of the past. They are heavier to boot.
